I really am just thinking off of logic... because although I've read about all this in the past I can't recall most of it. My sense of vehicle dynamics is based on logic and senses. The only reason I know if a part is doing its job or not is if the car feels right or not. If it doesn't feel right the first thing I do is analyze what parts are involved and how those parts might be broken or simply overworked. In order to analyze a part you have to figure out how its made. The beauty with cars is even though every part is different for each car they all basically do the same thing. If you know what its supposed to do just use your imagination to reverse-engineer-it based on what your senses can tell you about it.
For instance with a shock absorber I can tell its designed to compress and rebound and is filled with air and oil and some valves. I've never taken one apart and I've never seen the actual valves but I know how a car normally feels with good shock absorbers matched with the right springs. The rest is common-sense and deduction.
Now back on topic... My car is bouncy. Adjusting tire pressure helped but it did not solve the issue.
The bounce I'm feeling is the result of minute, but sharp, unchecked-rebound and compression. From this feeling it should be obvious that my springs are too stiff for my shocks. I have to change the shocks... I'll have to wait to buy aftermarket shocks so would it just be more prudent to ditch the springs?
So now I am left with 2 options. Abandon the springs or live with the springs? I am planning on taking my 86 to an autocross at the end of the month I think I should make my decision after that.
Now I took your advice and checked out the stickies in the suspension section. If I had done this in the first place all this ^ analysis and deduction would not have been necessary! :p ...observe, I've emboldened the words that jumped out at me lol
damn I'm already lowered over 3" I fail :p
