Results 1 to 5 of 5
Thread: cooling fan relay
    LX User fijisac's Avatar
    Feb 2009
    1989 honda accord LX
    sacramento, california. 91sickness
    cooling fan relay
    is it possible 2 have both cooling fan relays stuck in the closed position and could had b the cause my coolong fan being on all the tine?
    Millington, TN
    Re: cooling fan relay
    That would be one of the first checks I'd perform. One fan is from the cooling system when your coolant temps rise(left side) the other is for the A/C system (right side) When you have the A/C button engaged this will engage both fans.
    Phil
    since I don't have ac,i'll just get rid of the factory mess with the diode, and use the coolant temp sensor and a couple of bosch relays. if there is current from the ignition circuit through the temp sensor, when it calls for cooling it switches on two relays. the sensor will only turn on the relay coils. key off fans stop. does anyone know where the current to operate the fans comes from itself? it's the underhood fuse box right?
    Feb 2009
    well i pulled 1 of the relays out while the car was open and it turned off and when i put it back da fan came back on, so would that indicate that the relay(s) r stuck closed? and i did this when the car was cold (then i first started 2day)
    Feb 2009
    well i think cause thats where da relays r at
  1. Replies: 1
    Last Post: 08-25-2008, 05:59 PM
  2. Cooling fan
    By mark_salad_bar in forum Classic Honda Community Chat
    Last Post: 06-03-2008, 08:55 PM
  3. Hot Day + A/C + Cooling
    By mindlos in forum 3geez Accords
    Last Post: 07-07-2004, 07:29 PM
  4. Cooling fan/s never off!!!
    By blahblahblah in forum 3geez Accords
    Last Post: 05-24-2004, 03:32 PM
  5. cooling fan
    By Nate2310 in forum 3geez Accords
    Last Post: 12-24-2002, 06:52 PM
