Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: Drawn through 'Boed a20a2?
    hopefully something that DOESN'T break everytime you try to fix it
    idaho. burley to be exact
    As the name suggests, I am interested in setting up my 3gee with a draw through turbocharger using the stock carb. anyone had any experience with it? A nice run down of everything needed would be swell..
    please no responses along the lines of "why bother when this is better" and the like ;-)
    EDIT: i have read the topic on the matter, but can make no sense of any of it. Is all a jumble of arguments.
    honduh
    Re: Drawn through 'Boed a20a2?
    umm.
    ahh thanks, i'll try that.
    honduh
    Vanilla Sky's Avatar
    1999 Penalty Box
    A new carb is the first thing you'll need. Our stock carbs barely put out enough fuel for just a few mods, much less a turbo. There's a reason you don't see any turbo Keihin 3geez. You really would be better off going EFI. If you must stay with carbs, you could always go DCOE and start thinking about serious power.
    89T's Avatar
    Apr 2004
    you need some timing control as well.
    un-motivated!
    3GR
    carotman's Avatar
    Montreal South Shore
    The stock carb will not deliver enough fuel for a turbo. You need something else.
    Thanks for the replys guys. They don't make bigger jets for our keihins? And just kinda throwing this out there as i'm not looking to build the fastest 3gee in the world, but i have an opportunity to rebuild and own a garret t3 and thought i'd put it to some good use. Thanks again
    honduh
    1999 Penalty Box
    Nope, the keihin carbs were never made to be upgraded. Just trash it and install a weber.
    There's a reason we don't bother with performance on the keihins before we upgrade the carb. It's a pile of shit.
    yeah hte exter cash for a webber 42 should be worth it
    Well i'm not really finacially inclined at this point. The only reason this is a possible idea is because i have received this turbo for free, and my dad being a machinist, could help me fabricate whatever i needed. Are there any ideal carbs off of any stock vehicles i could find in a junkyard that would work? i'm thinking something along the lines of a 2 barrel carb off an 80's four cylinder ford pickup or mustang or something of the like? Seeing as i would need to fabricate a carb and intake flange, this sounds like a reasonable idea. I do recall some of the 80s 2.3t mustangs being draw-thru turboed.
    honduh
    1999 Penalty Box
    Weber DCOE40 carbs were common at one time. You have to find a matched set, though. If you can find them, they were a popular swap on old Alfas, Fiats, and Triumphs. You can purchase the required manifold from the marketplace here at 3geez.
    For the price, you're better off going with fuel injection. There's a reason we do things the way we do around these parts.
    Might want to look at the Holley 2300 two barrel. Very popular but i dont know about the draw thru turbo parts but its the same flange as the 4 barrel carbs are.
    There is some one that ran one here but he got drummed out pretty quick.
    AZ
    "i don't have money but i want to mod my car" is what i just read... focus on normal things like ball joints and other neglected points on the 3g that could cause your potential death.
    dead white and blue
    x2...thats what i said UMMM
    Thanks. Clearly you didn't read the topic i posted a few months ago when i bought the car.
    Here it is : https://www.3geez.com/forum/showthread.php?t=68233
    Also, here is the paragraph i'm talking about from that topic, "other than the engine, the car is mechanically and cosmeticly sound, its got a new alternator, new CV joints, new wishbones, a new clutch and shaved flywheel, new motor mounts (beyond me why they chose to put A-series in) new front clip, interior is immaculate, its been sanded, and primered, the springs have been cut, but it doesn't have the notorious "ricer bounce"" The kids next task was rebuilding the engine. Apparently he waited a little too long.
    The car will get me down the road just fine. Its because i have a garrett t3/4 turbo sitting next to me, and a mill, lathe, and miller TIG welder in my garage, that i am considering this project.
    Back to the subject, Vanilla Sky, OldBlueaccord, thank you. I will search up and see if i can find either that weber or holley in any local salvage yards.
    Thanks again to all.
    honduh
    AZ
    no i'm sorry i don't go trhough peopls threads.
    off the topic, what are wishbones? lawl.
    dead white and blue
    A-arms. Sorry, i grew up around 70's muscle cars, not Hondas. and people who know everything about 70's-80's muscle cars. not Hondas
    I guess i thought someone that knew as much about these cars as you do, would know what kind of suspension is under them.
    honduh
    cygnus x-1's Avatar
    Chicago area
    Generally speaking, a carb is a carb is a carb. So you can use anything that you're familiar with, assuming you can get it plumbed up. The stock carbs were designed for fuel mileage and low emissions, so they barely have enough flow for the stock engine. A Weber 38 would be a good choice. Fairly common and parts are available. Also very simple and easy to tune. You won't find one in a junkyard though.
    You could try something from an older domestic but it would have to be fairly old. By the '80s most of the OEMs were either switching over to fuel injection or were loading up their carbs with electronics and emissions controls. And you don't want that crap.
    Keep checking Craig's list end ebay too. There are deals out there if you look hard enough.
    C|
    AZ
    hahaha, i know quite a lot about the suspension, never heard anyone refer to anything on them as wishbone. you have lca's and uca's though?
    really though with no money this is going to be damn near impossible, the accord isn't the platform to really spend "little to no money" on...
    dead white and blue
    LX User JFern's Avatar
    1986 Honda Accord LX-i
    San Diego, CA
    i know quite a bit about 60's and 70's cars (built about five now). Never heard of anyone refer to it as a wishbone. Control arm? yes. A-Arm? yes. but everybody has pet names for their own parts. So as for this lets see who penis is bigger b/s, just please stop and take it somewhere else, we are here to build cars not compare inches. (i have been a part of too many forums that just fight, this shouldn't be one of them)
    As for trying to get a carb off a stock car to work? good luck, even manufacturers were smart enough to have EFI on their cars for turbo applications (examples? the 80's mustang 2.3L EFI, and the 80' thunderbirds 2.3L EFI, Rx7 turbos are EFI etc.) if you need a carb to do turbo, buy a holley because you can get jets for them easily and just build the flanges and stuff to fit.
    "You may have beat me by .2 seconds but i only spent $2000 on my car, hope that extra $25000 was worth it" My famous last words
    Really? Yeah my accord has upper and lower control arms. What will cost money besides the carb?
    honduh
    AZ
    all of the other parts you will need to do this project PROPERLY...
    i guess if you just kind of slap shit together that's fine... but the motor won't take a lot of boost even if it is just a draw through...
    checkout www.homemadeturbo.com they had a good draw through setup on a yota truck i believe... if i can find a direct link to it i will...
    dead white and blue
    San Diego, CA
    Quote Originally Posted by JordanQ View Post
    well if you do it right (and considering you said you had only the turbo it self and its in good condition) ..... The carb itself, materials, new parts for the carb (ie jets etc.), gaskets, the tubing for the turbo as well as the oil lines, an exhaust manifold, wastegate, blowoff, intercooler, piping for the intercooler, an ecu flash (unless you are doing a complete standalone) and a bunch of other stuff you won't foresee (because building cars always seems to take 3 times as long and cost 3 times as much)
    San Diego, CA
    oh ya its draw through.... x2 with static (build it right or not at all imo)
    1999 Penalty Box
    I do want to point out the infamous Maserati Biturbo. Those are awesome cars if you swap to fuel injection. Even the stock pressurized Webers didn't do well.
    I'd pick myself up a $50 LXi or SEi parts car and just swap to EFI. That way you also have a spare motor to mess with. If you were local to me, I have one I'd sell to you for $100.
  1. WTB: A20A2 carburated engine
    By JordanQ in forum Wanted
    Last Post: 05-19-2010, 07:21 AM
  2. A20A1 vs. A20A2
    By zigzag in forum Classic Honda Community Chat
    Last Post: 05-27-2009, 10:20 PM
  3. Any1 want there car drawn?
    By Zwaag in forum Classic Honda Community Chat
    Last Post: 11-24-2005, 06:22 PM
  4. Help with 87, A20A2 going through fuel??
    By FIVE 7 in forum Carburetor Tech
    Last Post: 12-21-2004, 07:02 PM
  5. i want to know wich is better bs1 a20a2
    By SHURIK in forum 3geez Accords
    Last Post: 10-24-2004, 10:04 AM
