1987lxi
It depends... How much power are your amp(s) pushing? If you pushing less then 450 you should be fine with that. Any higher than that I'd recommend 4 gauge. Once you get into the 800 watts or more you'd need a bigger wire. If you don't know already, the gauge system runs like this..... The higher the number the smaller the wire, the lower the number the bigger the wire. Remember, the wire has to be able to carry the current, and the fuse has to be big enough to pass the current without blowing. Don't put a big fuse on a small wire, it may over heat and become a problem for you and you're car. That kit may be a good one. However, it depends on what it's going to be used for.
