Results 1 to 9 of 9
Thread: Rod Bearings
    Rod Bearings
    I dropped my pan since im going to retap it proper for the setup i have.....But for the heck of it i just seening how much slop i had on my rod bearings...i a have a slight movement up and down...im not saying its like WHOA..but like barly you know. I was woundering how much is okay... I dont knock but im thinking i might plastic gauge and just replace em...they move side to side of course but that doesnt matter. i know the play is what is not good correct...Yet idk every engine is different...
    let me know crew.
    Ill prolly just get some oem ones for now if i really think i need em...going to have a buddy come and check it out tommorow....REMEMBER I DONT KNOCK...or have shavings.....i see some but idk i used alot of that gasket market seems like it mixed in with the oil LOL....not good
    Re: Rod Bearings
    If you could feel it, I would think you'd hear the most unearthly clatter under the hood. Are you sure that it isn't just the crankshaft moving?
    Re: Rod Bearings
    No...the crank isnt moving....the all have the same almount of play so im prolly okay. was rebuild along while back...so im assuming its getting close for bearings....
    But anywho im going to start buying parts for my new build just incase this block takes a crap...BUt i dont think so...runs like a dream. o and i had chunks of gasket maker stuck on the bottom of the pan making it seem i had shavings. its that import gasket maker and its grey....Im the fool that used that to hold the gasket in place LOL....o well i got some sealant and should take care of my issue.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Rod Bearings
    you will always have a few thou of up/down movement in the bearings, both crank and rods, is just oil clearance
    Re: Rod Bearings
    Thats what i taught man.....Thanks for clearing that up
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Re: Rod Bearings
    If you really want to know pull the bearing caps and use some plastigage. It doesn't cost much and shouldn't take long and then you'll know for sure.
    Mike
    Re: Rod Bearings
    I just baught some. not going to risk the motor. I mean runs good but its different when you inspect things. Seening and hearing is a whole different story lol
    Nov 2002
    Ridin Dirty in New York
    Re: Rod Bearings
    be sure to check your center main bearing, #3. thats where the most damage and wear as far as bearings are concerned, in a20s seems to be. The #3 main bearing damage is what killed my first boosted motor, and made me get another crank for the 2nd engine build (i scrapped the first motor and engine entirely) they chew the bearings up and damage the crank main journals.
    Re: Rod Bearings
    Good to know bro...well do
  1. IH8 bearings!
    By rfiks in forum 3geez Accords
    Last Post: 11-15-2008, 10:27 AM
  2. ACL rod bearings
    By LiTtLe xOx BitT in forum Performance
    Last Post: 03-13-2007, 02:25 PM
  3. Rod Bearings
    By azazel_18_2 in forum Performance
    Last Post: 11-23-2005, 10:00 AM
  4. hub bearings
    By dXsquared in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-17-2002, 03:45 AM
  5. How-to get Bearings out from Hub
    By SiR in forum 3geez Accords
    Last Post: 10-12-2002, 09:16 AM
