Alrighty so for the past year I've had horrible vibrations when in D4 and not moving.. So I adjusted the idle screw (keep in mind its a carburated a20a1, automatic) and raised the idle to around 1000rpm in D4 and it went between 1200 and 1500 in N or P (horrible for the car I know..)
Anyway I got ALL 3 mounts done last night and found out 2 were shot, the front mount was all messed up..
I've lowered the idle to around 750ish for drive and the car still vibrates, and sometime wants to die..
That and it fluctuates slightly like I have a vaccum leak (which I shouldn't I just replaced the bad lines an checked them all a couple of months ago)
Anyway, does it take some time for the mounts to wear in to where the vibrations will stop, I guess I was just dreaming the mounts would of fixed it the second they were put in lol..
Any info would be helpful, or personal experiences with soft mounts
EDIT - I used the idle stop screw to adjust the idle (bad idea Y/N?)
