Results 1 to 25 of 35
Thread: picture request - 15x8 +35 offset
    LX User Importordomestic's Avatar
    1988 Accord Hatch
    Hueytown Alabama
    anyone running or have a picture of a 15x8 with a +35 offset under a 3G?
    I run auto x and circuit, and wondered what the 15x8 with a 225/50 or 45/r15tire looks like. (also interested in the 16x8 as there are more tire choices) im currently running a 215/45/15 on a 15x7 but every little bit helps.
    If you have this tire and rim combo or currently run it, did you have to flare the fenders and quarters at all?
    Thank's
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Re: picture request - 15x8 +35 offset
    I currently don't know of anyone on the board running an agressive setup like that, please chime in if you are. However I am running 15x7 +27mm offset with a 195/50/15 and had to roll my fenders in the rear quite a bit, so I would imagine some agressive rolling would be required for that setup, I would imagine it would fit decent though.
    Feb 2004
    89 accord lxi
    down by the bay
    Is it the 949 wheels that you're thinking of? Cause those are the ones I have my eye on. The new hankook rs3 comes in a 225/45/15. I think it would fit perfect.
    1988 Accord Hatch
    Hueytown Alabama
    If you are running a 15x7 with a +27 and you had to roll the fenders what type of clearance do you have between the back of the rim and the knuckle?
    No matter what I do I am goign to have to drop a load of cash to get rims this size and I want to make real sure they are going to fit with the rubber on them.
    1988 Accord Hatch
    Hueytown Alabama
    Quote Originally Posted by Strugglebucket View Post
    Never heard of those rims but Im looking at them now However I am looking at the hankook rs3.
    SEi User 86ccord's Avatar
    Middle Georgia USA
    hah its all about the CCW classic fours son!!!!!
    one day I'll return.
    i have 15x7 with 35mm offset i think? but i have 205/55 tyres. those are them in my sig VV
    but you also have one very slammed 3g ^_^
    at stock 3g height u could probably fit some 32" mudders
    1988 Accord Hatch
    Hueytown Alabama
    According to my best calculations it will fit under the car. i should have 1/2'' clearance between the rim and the knuckle in the front and a 1/4'' at the knuckle and sidewall. The rears should clearance no problem. BUt yeah it will take an agressive fender roll and possible extension to tuck these puppies in under the car.
    oh and these are the rims im going to use: http://www.rotawheels.com/wheels.asp?wheelid=34
    Rim and tire calculator allows for side by side comparison - http://www.wheelsmaster.com/rt_specs.jsp
    Calgary, AB, Canada
    Quote Originally Posted by Importordomestic View Post
    I will double check the clearance tommorow, and snap a pic too, but I believe there is plenty, and yes my car is very low lol.
    I like the choice in wheels, should look really good on a 3g.
    im 15x8 with 205/50/15.....RIDES perfect. you can put a sheet of paper on the rear....LOL thats how much gap from tire to fender.
    with a 2 3/4 drop on front and 2.5 in the rear.....custom status LOL....Eibach made there springs so the front end was higher...i didnt like it so i cut a link and a half off and looked clean. repainted them red and bam. rides good even drop a bit more when it settled.
    1988 Accord Hatch
    Hueytown Alabama
    Oh thanks alot man. The pictures will really help alot. And as for the rim they were the best style for the price I could find. Konig makes one called the rewind that looks almost identical. The rewinds are a little cheaper Alot of the Mini cooper guys run but I just like the Rotas better.
    1988 Accord Hatch
    Hueytown Alabama
    If your close with a 205/50/15 i know im giogn to have to roll the lip with a 225/45 or 50/15
    My car is lowered as well which is a major concearn for me. But seeing that you have such an agressive drop compared to mine and manage to tuk them under the fender i wont have any issues.
    Thanks for all the replys guys. I am giogn to stay the course and move forward with the rotas. I will keep you guys updated. still up for pictures tho.
    thanks
    O yea you would have to roll the rear lip...i had to.
    1988 Accord Hatch
    Hueytown Alabama
    Im not lookingforward to the fender roll, gogin to chip my memphis pearl blue paint.
    now its on to my next project. 11.75 wilwood rotor and 4 piston caliper. Going to give Brian at fastbrakes a call see what he can drum up for me.
    I don't think you will be able to fit them under a 15" wheel but Brian would no for sure.
    1988 Accord Hatch
    Hueytown Alabama
    I called Brian yesterday after my post before, and he has a way to piece a kit together for me that will fit. 11.75'' 2 piece rotor using a civic 4x100 hat using the superlite caliper. And at a great price of 1,300
    a pile of lawn ornaments
    Newtown, CT
    I went through this very issue a few months back. I ended up calling the boys over at Wilwood directly and we came to the same conclusion of using the Civic tophat, and the (don't quote me on this, I need to go back to my notes to confirm) rest of the Miata kit with the superlite on the 12" (I think) rotor. The relocation bracket is the only obstacle to overcome, but the Civic bracket may work with minor relocation.
    As for the wheels/tires... Those Rota's should treat you nice, and as you mentioned I've heard of and personally seen great success in the Konig Rewinds. To be honest, an ET+38 on a 15x7 is a very very tight fit to the fenders. It's pretty much a guarantee you'll be rolling the fender lip for clearance. If you did go with the extra 1/2 inch (15x8 as opposed to 15x7.5 or 15x7) IMO you're flirting with knuckle-rub. As for tire size, a 225/50 is substantially oversized (in diameter) to stock. A 215/45 or even 225/45 is a little closer to stock, but still oversized.
    Good luck with whatever you do. This should be an interesting project indeed.
    What suspension setup are you currently running?
    Here's a shot (for what it's worth) (oh and please please please don't knock me on the car being soooo dirty) of my Konig's ET +38 15x7 with 205/50-15 Kumho VictorRacer V700's. I would have gone with their 7.5, but it's only available in ET +0 so there was NO way it'd fit and the tire would have looked stupid.
    -Mark D.
    1988 Accord Hatch
    Hueytown Alabama
    Well thank you kind sir for all your input and i would not intentionally nock anyones car. I get shit all the time for my 3g at the track, and it makes it that much better when i pass the porsche in the corner.
    Those tires look great under your hatch. I have my rotas in got them in monday. But I dont have rubber on them yet. Right now im inda torn on what to put on them. Im definately going with the 225/x/15 i have 3 choices really
    hoosier a6 competition slick 225/45/15 The treaded Rs3 225/45/15 or the more variety kind of zr rated tire of 225/50/15 (many more treaded tire choices in this size)
    im leaning more towards the hoosier a6 tire as im about to have my ls vtec turbo ( i have a build thread coming real soon) finished and will need a super grip tire
    yes the 225/50/15 will give me around a 2.8% difference in speedometer reading and it is bigger but the rim should only sit 8mm closer to the suspension and stick out almost an entire inch. i will have some pics of the rim on the car later this weekend.
    Do you have a picture of the 12 inch rotor inside your 15 wheel? 11.75 is fine with me the brakes will be completely retarted combined with the 11inch rear rotors and the massive amounts of rubber under the car. My big issue now is the brake master cylinder. cant decide to keep the power brakes and go to a 1inch master from the 4th gen accord or do away with it all together and run dual master cylinders with a balance bar.
    also on my list is some type of ducting to bring forced air to the brakes as I love endurance races and i have yet to be able to run one all out the whole time due to brake fade.
    my suspension setup:
    1997 honda crv weaponR dual spring coilovers around a spring rate of 8modded top hat to fit accord with re-valved tokiko blues. all new oem factory bushings and ball joints. 87 front prelude upper control arms adjustable rear links for camber and custom toe links for rear tow. ST front sway bar poly links 24mm, Progress Technology rear 22mm sway bar fro the 4th gen accord. and also run the ST rear bar 16mm when I go to a bigger track.
    - im looking to go to ksports full bodied ciolovers in a year or so just so i can have more spring rates and adjustable suspension like ive never had before.
    any more questions please feel free to ask, im not secretive about my car and ill take pictures or help in any way I can. I would love to meet another 3 g on the track one day.
    ps i have parts for sale: https://www.3geez.com/forum/showthread.php?t=70825
    88 - Hatch - FF class track car Major Upgrades!
    87 - Hatch - DD
    88 rx7 turbo II - FR class track car - blown engine
    86 rx7 NA - Under Construction
    90 240 hatch - SOLD
    Other way Instead of rolling the fender is cutting that lip. Alot of people with civics take there cars to a auto body shop have them cut it away. which is prolly easyer then rolling. just tape and get a dremel and cut away.....thats what my brother did to half the civic he painted. This is on the rear BTW
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    DON'T get 225 tires if you're not willing to roll your rear fenders! I'm currently running 225 tires on ET38 rims and theres no way in hell they clear without a good bit of rolling.
    Link to my 3geez garage
    1988 Accord Hatch
    Hueytown Alabama
    Quote Originally Posted by thegreatdane View Post
    I'm sorry if I came across as not wanting to roll the fenders, I am willing to do anything that it takes to put that tire under my car. I have rolled fenders before I was just curious of what it would look like with or without rolled fenders.
    OH and your white rotas that you have on your sedan look so freakin good!!
    your car looks so nice, everytime I see your sig It makes me want a EDM front end. I imagine the front is a few pounds lighter as well.
    I wonder If i could talk one of you guys into shipping me a pair of fenders, hood, markers and headlights?
    87 - Hatch - DD
    90 240 hatch - SOLD
    Newtown, CT
    I do know one of our members that has an EDM front end may be willing to do this for you if you're seriously interested.
    As for the lip, like what Ren said, I do like the idea of cutting it. ...I cut mine partially (about half the length) and rolled the rest. My only gripes about rolling it is that it creates a rain gutter where a lot of crap can get caught in it and cause things to rust out a bit faster. Just for clarification, you shouldn't need to roll the front fenders, just the rears. I'm not sure if you've considered it, but the 225's up front will keep your front glued to the ground, and a 205 out back would still give you plenty of traction, but you'll be dragging around a bit less mass back there. ...and that should allow you to get away with an ET+38 out back without rolling (or at least without rolling too much).
    I'm really excited to see this project of yours with those monster wide tires stuffed under there, and see your car out there at an HPDE.
    Oh and I don't have that Wilwood setup just yet. I'm waiting for funds to allow. ...but theoretically they'll fit under a 15" wheel. If not, 16" is going to be an option for me, but absolutely nothing bigger. I like the idea of the 15"s because I have a (seemingly) endless supply of 1-event used R comps (Ecsta V710's) at a great price but only in 205/50-15. ...so for Auto-X and a few track days I should be able to get nearly a full season out of one set of tires.
    -Mark D.
    1988 Accord Hatch
    Hueytown Alabama
    Am I truly interested in a EDM front conversion = YES
    I'm goign to try and get away with not cutting the rear lips but it sems the most logical step at the moment. (just got through painting that car for like the 3rd time)going to have to the rear quarters again if i start cutting.)
    You bring up an excelent point about running smaller tires in the back will help with understeer as well. If i get a second set of rims I can run that setup. as right now running hoosier a6 racing tires they have to be rotated front to rear between heats.
    My project has been in the works for a total of 4 years and recently have a chance to make alot of headway, which is why im mysteriously back posting frantically on 3gz.
    Im going to get off my but and start a build thread.
    87 - Hatch - DD
    90 240 hatch - SOLD
    Jan 2003
    Denmark/Europe
    Haha thanks mate. I suppose the front is marginally lighter yea, but doing it to save weight would be nuts lol.
    I think that NZ dude called 3gcvc is your best chance at getting that front end shipped to you. I've seen him ship some crazy large stuff over for people on here and preludepower. They have the same front ends in NZ too.
  1. 15x8 with 4 Inch backspace. Tested!
    By mushroom_toy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-24-2009, 09:34 AM
  2. Offset?
    By CodyMacRae in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-14-2009, 01:14 PM
  3. Quick picture/explanation request (blower motor)
    By propr'one in forum Classic Honda Community Chat
    Last Post: 12-16-2006, 01:44 PM
  4. Picture Request...
    By jigga89SEi in forum Classic Honda Pics & Videos
    Last Post: 01-09-2006, 05:28 PM
  5. 89 DX Dash picture request...
    By Leviathant in forum Classic Honda Pics & Videos
    Last Post: 09-17-2003, 07:31 AM
