I've got a 89 lx that I have recently done a weber conversion on. The problem is after I hooked up the tv cable to the gas pedal it does not shift right. It is an automatic tranny. My question is does the trans lever Need to be fully down When resting and then does it need to go all the way up to ( besides the 3 mm freeplay) wot from that resting point?Also What are the stock shifting points?Any help would be greatly appreciated I'm going outta my mind!
