Results 1 to 25 of 31
Thread: Theoretical life of fuel injectors?
    SE-i Sedan 5 spd
    At 20 years and 220k, I have two slightly leaking injector seals (enough to smell gas, so it's time to do something). I gather the labor to take them out and put in new seals is around an hour, and the parts maybe $10 an injector. The alternative is to put in 4 new injectors, $96 ea from Majestic (I only buy Honda OEM). My question is, am I approaching the point where the original injectors may start to fail? If so, I'll take this opportunity to replace them all. Thx.
    snoopyloopy's Avatar
    Killa Cali
    Re: Theoretical life of fuel injectors?
    hmmm well i'm at almost 287 and my injectors are still working and i do believe mine are originals. although #4 is leaking about as bad as yours (maybe worse, i can actually see damp around it at times), so at least a seal job is in the works for me sonon. but yea, if anyone has any clues as to life expectancy, i'm taking suggestions too lol.
    Quote Originally Posted by w261w261 View Post
    there are some pretty good aftermarket injectors out there now, I would look around before buying new ones,
    SE-i Sedan 5 spd
    My problem with the aftermarket is I don't know what is good and what isn't. I suspect that different batches of the same "brand" may be made by different factories in possibly different countries, all dependent on who could score the business on the latest contract. Today's good injector from xxxx is tomorrow's crap. The best chance I have of purchasing consistent quality is let Honda do the QC. That does cost money, but peace of mind is worth something too.
    I remember a couple of years ago I put in a new axle. I got it from Honda, and had a chance to look at a promotional piece for their OEM replacements. 3 different kinds of grease, etc. I couldn't help but be impressed, but they weren't 50 bucks each, either.
    I did draw the line however, when a new dizzy from Honda was $600+.
    SE-i Sedan 5 spd
    Unless I hear something here, I'm inclined to just put in the seals. The cost is relatively small, so I'm not losing much if the injectors themselves go later.
    RC Injectors are supposed to be really good... i also here alot of good from Injector Rehab if you just want to send yours in for flow chart and cleaning.
    Nov 2002
    Ridin Dirty in New York
    you can get em cleaned and flow tested, i really dont see the need to buy brand new ones
    Vanilla Sky's Avatar
    1999 Penalty Box
    There really isn't much of a reason to replace good injectors if you're stock. Modern fuel injectors last a LONG time. Typical failure is due to muck that accumulates over time. Having them cleaned and flow tested is all they ever need. RC Injectors seem to be the choice of a lot of DIY types. I see no need to go to Honda for something that likely comes from a 3rd party distributor anyway.
    SE-i Sedan 5 spd
    I'm having no performance problems, and I use Techron regularly, so I assume the injectors are flowing fine. So I guess it's the solenoid that might wear out....I'm just going to put in the new seals.
    I had two start leaking pretty bad at ~175k miles. I thought it was seals, so I replaced them to the tune of $40. You can't replace just one seal because they all go when you remove the fuel rail. The seals didn't work. The injectors themselves start to leak from the seams in the housing. I'm not sure what they do when they clean and flow test, but I suspect it won't help if the injector case is leaking. I replaced two injectors and now the other two are leaking. I just grabbed some junkyard jobs and I'll swap them in when the leaking gets real bad. Your estimates for time and cost are about right. For what it's worth, my injectors leaked for a very, very, very long time before it got to where I was in danger of an engine fire or asphyxiation from the fumes.
    SE-i Sedan 5 spd
    ....... injectors themselves start to leak from the seams in the housing........ For what it's worth, my injectors leaked for a very, very, very long time before it got to where I was in danger of an engine fire or asphyxiation from the fumes.
    I gather that when you removed the injectors, you then could tell that the seams were leaking from the stains or wetness? I get a noticeable gas smell in the car, with one injector definitely wet and another kind of.
    I changed mine 6-8 months ago. I got a good deal on a set of 255's from RC. If you call them they might have some slightly used ones I think they were 60$ a piece. Mine leaked from the body as well. I rode them as long as I dared but the fuel smell started to get to me and my wife would not ride in the car anymore. I notice no impovement in idle quality, mileage or and other runability issues.
    Nov 2000
    You'll be wasting your time and money replacing the seals. The injectors are leaking at the joint between the plastic and metal portions. Yes, they are working fine, but the leaks will only get worse. It's time to replace the injectors.
    May 2008
    los angeles
    Quote Originally Posted by snoopyloopy View Post
    not as bad as mine lol... i turn the key to prime the system and cylinders 1,2,4 sprayed like a garden hose.. i just replaced the seals on the rail and i was good
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    Quote Originally Posted by 1987AccordLx-i View Post
    i remember when my civic did that! i just went to true value and got 2 tiny sprinkler o rings or something like that and put 2 of them on 1 injector haha it worked
    Nov 2002
    if the injectors themselves are leaking, replace them
    injectors have moving parts inside, they wear out in time, the only kind of injectors i've seen rebuilt are diesel injectors and aircraft ones. mostly because of the replacement cost. not something you can rebuild at home.
    That's something of a long story. I noticed staining around the injectors about 50k miles before I replaced them. I started by replacing the seals but after 50k miles I noticed the staining returned and I could smell a lot of gas. Short answer is that I changed the seals and it didn't fix the problem so that's how I knew.
    I don't want to say your injectors are leaking. I just know that the seals weren't my problem. I'd start with the seals because they are relatively cheap. If you change them and the problem remains, replace the injectors. If you don't drive for thousands of miles in the meantime, you can re-use the new seals so no sweat.
    May 2004
    I believe you can tell if the injector itself is leaking or not - if the stain coming from between the plastic & metal parts of the injector - it needs to be replaced. I have to do 2 of mine soon ('86 Lxi, 272,00)
    David
    If the injectors have a lot of miles and you think they are leaking,it's time to replace, they are one of the parts that simply wear out. even if they aren't leaking, chances are they may be leaking internally into the cyl or they are worn enough to affect the spray pattern , this will also affect your performance and fuel mileage. think how many times that pintle inside of the injector has opened and closed over a few hundred thousand miles. they are precision devices, they are probably shot.
    here's a cutaway of a typical injector, you can see there's a lot more to it then you may realize
    here's a bunch of info from them http://www.witchhunter.com/injectorcut1.php4
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    I replaced the seals on mine once, didn't do anything. Two injectors were leaking at the seam where the plastic top meets the metal body. Check the back of the seams for built up fuel varnish.
    CARDONE SUCKS.
    1999 Penalty Box
    Those look like they're leaking from the seams, not the seals. Whiles seals don't cost much, I'd just replace the whole injectors, all 4 of them.
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    It is optmal to change all injectors at the same time, so that all spray patterns are equal on high mileage injectors. And from what I understand, those cheap injectors that you see for $39 or whatever, are just that. Cheap. On the cheapos they are not calibrated precisely, and can take out your ECU in some cases. How it can take it out I can't tell you, I am a Hot Rod builder and my buddy who I trust at another shop told me this a while back. The RC's I believe are around $88 I believe. I used to live in Torrance 2 minutes from them, but now about 30 mins. away.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
  1. Fuel Injectors
    By ProfileTrader in forum EFI Tech
    Last Post: 03-29-2007, 11:35 AM
  2. fuel injectors??
    By newtuner in forum 3geez Accords
    Last Post: 11-15-2003, 07:10 PM
  3. wtb: fuel injectors!!!!
    By B16 ED9 in forum Trading Post
    Last Post: 07-10-2003, 05:36 PM
  4. Fuel Injectors Please
    By makodragon in forum Performance
    Last Post: 10-12-2002, 09:14 PM
  5. where to get new fuel injectors?
    By jteuton in forum Performance
    Last Post: 06-30-2002, 11:30 AM
