Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: fuel cut-off relay question
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Re: fuel cut-off relay question
    Is 20 gallons per hour going to keep up with the 200-250 horsepower n/a build I'm planning?
    I'll be running quad motorcycle carbs on that setup.
    20 gallons per hour means you would burn through an entire tank of gas in less then an hour. I don't think you are going to be using that much gas. remember too you are not going to produce that much power all the time unless you are running somewhere like Daytona. car engines only produce their rated power in short bursts.
    Aug 2007
    Boise, ID
    heh. I guess that makes sense. Now I feel like a tard.
    if you were running 200 horsepower at maximun output constantly for one hour,such as on a dyno, the recommended fuel pump output is 22.89 gph, pretty close, and thats running flat out. remember too in a car once you accelerate and overcome inertia, you start to use a lot less fuel, it takes far less power to maintain a set speed then to accelerate to it.
    I had problems with fuel starvation at 5000 rpms.
    If your using aftermarket carbs you might have to upgrade the size of your lines to help with the volume.
    Aug 2007
    Boise, ID
    It's all 3/8th inch line now. Upgraded it when I did the pump.
  1. Fuel pump or relay?
    By bongbang in forum 3geez Accords
    Last Post: 10-11-2009, 09:12 AM
  2. Fuel cut off relay removal
    By nerdmeier in forum 3geez Accords
    Last Post: 03-24-2009, 12:30 AM
  3. fuel relay?not firing
    By kyaccord in forum 3geez Accords
    Last Post: 11-09-2008, 07:56 PM
  4. Fuel pump relay ?
    By 79cord in forum 1geez Tech & Performance
    Last Post: 08-21-2007, 05:30 PM
  5. 87 Fuel cut-off relay location
    By Poodlehead in forum Carburetor Tech
    Last Post: 06-22-2005, 01:33 PM
