Results 1 to 15 of 15
Thread: Tranny cooler?
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Tranny cooler?
    Alright simple question (yet it isn't in my Chilton manual)..
    What is the radiator looking thing in front of my radiator?
    I drive an automatic, is it the transaxle cooler?
    If so, does it ever need replacing <.<?
    Re: Tranny cooler?
    AC condensor, your trans cooler is actully in the bottom of your radiator
    Jul 2008
    89 Accord LXI
    Re: Tranny cooler?
    Wow that thing is huge, wish my A/C worked...
    Just wondering because I'm replacing the radiator and noticed it..
    Re: Tranny cooler?
    if you dont plan on fixxing your a/c pull it out, pulling that,the compresor, all the lines, compresor brakets (cast iron) and electricla can save u almost 80 lbs (if i remember someones weigh ins correctly)
    Jul 2008
    89 Accord LXI
    Re: Tranny cooler?
    I want it fixed, getting it done beginning of next year (hopefully it just needs recharged or converted..) I don't want to spend more than 400$ for it..
    Anyway does that thing ever need replacing? It looks to be in good condition, just a bit rusty looking...
    And should my new radiator contain the tranny cooler to (stupid question I'm sure)
    Re: Tranny cooler?
    they need replaceing if there rusting threw , they will have to check it for leaks and such before doing the a/c.
    and yes it should. you will see 2 small "nipples that fit a 3/8ths inch hose wich will be your trans fluid lines
    Re: Tranny cooler?
    Quote Originally Posted by CzEcHy View Post
    MY ac hadn't worked in ten years so i ditched it, I did keep the cast bracket though to move the alternator. everything else went. I have two air conditioners in front, a left and a right, and two smaller ones at the back,they pop open.
    Jul 2008
    89 Accord LXI
    Re: Tranny cooler?
    Alright well a rock ironically killed my radiator so it's a good thing I just bought one.. Really good thing..
    Anyway what type of antifreeze do I use? 50/50 ye? Any color or anything?
    Jul 2008
    89 Accord LXI
    Re: Tranny cooler?
    Also how much do I need to fill the little tank and the radiator?
    (I hit quote instead of edit, again, sorry..)
    Re: Tranny cooler?
    I was gonna tell you a bunch of stuff to do, but then I read your signature. LOL, it doesn't matter. The car will be dead soon, so just do the cheapest possible. LOL
    You can put the cheap green Prestone in. If you get the 50/50 pre-mix, you won't have to hassle with mixing it yourself. If you're feeling like a snob, Zerex G05 is very, very good.
    Re: Tranny cooler?
    ^^ whats rong with prestone lol hell im about to put PEAK in the civic tomarrow
    Re: Tranny cooler?
    they will get you on price though,it's much cheaper to buy non premixed and a couple of gallons of distilled water at the grocery store. dump each gallon of water half out, fill it back up with antifreeze,cap and shake. now you have two gallons for the price of one gallon of premix
    Jul 2008
    89 Accord LXI
    Re: Tranny cooler?
    It isn't that bad I put about the same mileage on the car as a normal person driving to work every day (small pizza place)
    Anyway I'd like the most decent, average coolant.. Just whatever my Honda will like..
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: Tranny cooler?
    I bought non-premixed and mixed it with water; I had a couple of plastic gallon bottles around and did the mixing there; it's not a big deal. Besides, you'll get some mixed stuff in case you need it.
    Re: Tranny cooler?
    I'm not real hip on spilling the coolant everywhere while mixing and then storing the spare gallon for the next two years till I change coolant again. I used to live near a gas station that sold pre-mixed coolant in quart sized containers. I had a leaky cooling system at the time and always had one of those in my trunk. I'd fill with gas, fill with coolant, check the tires and not have to worry about slopping coolant over everything. God it was wonderful.
  1. Tranny Oil Cooler
    By dalinxz in forum 3geez Accords
    Last Post: 06-03-2007, 12:49 PM
  2. tranny cooler
    By DLB in forum Performance
    Last Post: 03-27-2004, 01:56 PM
  3. need a HOW TO on tranny cooler installation
    By hondamanlxi in forum 3geez Accords
    Last Post: 08-18-2002, 03:52 PM
  4. tranny cooler????
    By HondaManDan in forum 3geez Accords
    Last Post: 08-02-2002, 04:40 AM
  5. Cooler tranny tips
    Last Post: 07-31-2002, 01:18 PM
