Results 1 to 7 of 7
Thread: Valve seals
    Valve seals
    It is time to do the valve seals on my 3gee. It puffs out a lot of blue smoke when its very cold out and it sat over night. It also burns a quart between oil changes so I am 95% sure its the seals. Anyway, questions is what is the best method on preventing the valve from dropping down? Do I do the old fashion rope trick or hallow out a spark plug and use compressed air? Also, what brands do you guys recommend for seals?
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Valve seals
    I'd go with compressed air. As far as seals, probably would get what Napa can order or OEM.
    Re: Valve seals
    only thing that would worry me about compressed air is that all the air might cause a head gasket to leak if it has a week spot but idk since the engine is probably under alot more stress when actually running lol...
    and instead of hallowing a plug why not just get a cheap compression tester and use the hose with the attachment on it? lol
    Re: Valve seals
    160psi vs 20psi to hold the valve in?
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: Valve seals
    didnt i tell yah i thought i saw stuff outta the tailpipe going to E-town? just go to a hardware store and make a chuck for the air line , ive used around 25psi to keep the valves where they are when i did them in my olds V-8 . heck LOST had a good idea using twine or something as a fail safe . its easy to replace the seals , just getting the springs and retainers is a pain
    3Geez resident body man
    Owner of Wreck-less auto body
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: Valve seals
    I did the rope trick when replacing valve seals on my Civic. Easy to do, cheap and safe. I would do it again. I got my seals from NAPA.
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Re: Valve seals
    I replaced mine bhy rotating the engine to TDC for each cylinder. I was not comfortable with this myself but had experienced mechanics with me while I was doing it. With the piston at TDC the valve will not drop far enough to lose it.
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
  1. Valve seals?
    By Buzo in forum 3geez Accords
    Last Post: 04-26-2013, 07:41 PM
  2. Done valve stem seals now have oil leak.
    By mushroom_toy in forum 3geez Accords
    Last Post: 09-21-2007, 02:17 AM
  3. Valve Stem Seals
    Last Post: 09-16-2007, 07:36 PM
  4. q: valve seals?
    By davke in forum 3geez Accords
    Last Post: 09-14-2006, 04:24 AM
  5. Valve seals
    By Sabz5150 in forum 3geez Accords
    Last Post: 03-01-2004, 02:39 PM
