Results 1 to 14 of 14
Thread: PLEASE help me, its so cold
    LX User canadian357's Avatar
    Feb 2008
    '88 Accord LX, '87(?) LX-i
    Edmonton, Alberta, Canada
    I need to figure out what my electrical problem is. My car runs fine when its on, no power loss, newer battery, but as soon as I turn it off and try to start it again it acts like all the juice gets sucked out of the battery at once as soon as I turn the ignition to the start position. Any ideas? Its so so cold out right now
    Feb 2008
    Re: PLEASE help me, its so cold
    Its my lx-i by the way. And on a side note, not as important, but my tach flips between 3000-4000 rpm when I'm in neutral or park, even though its at a smooth low idle. However while driving it works fine.
    Feb 2008
    Aaaaaannnnd, my window was stuck down for a while but when I replace the little relay/fuse underhood it worked ok, but that was only for like 2 days. Now its stuck halfway down again. Any ideas what's killing it?
    Millington, TN
    CAn you jumpstart it?
    Phil
    carotman's Avatar
    Montreal South Shore
    There's a couple of things to check
    The battery might be bad
    The wires might be bad
    The connections might be bad
    The starter might be bad
    Check every one of those.
    89T's Avatar
    Apr 2004
    Quote Originally Posted by SHENANIGANS View Post
    Aaaaaannnnd, my window was stuck down for a while but when I replace the little relay/fuse under the hood it worked OK, but that was only for like 2 days. Now its stuck halfway down again. Any ideas what's killing it?
    bad window motor. replace it and the relay again.
    sounds like the window motor is pulling too much amperage causing the relay to fail. not enough to blow the fuse but enough to cook the relay.
    un-motivated!
    3GR
    Feb 2008
    I know the battery is good, I pulled it from my other 3gee and it was gold before this. I got it tested to be sure and its good. As for the other stuff... there are old crappy terminals on the battery cables so I'm going to run new cable, or possibly replace it from the other 3gee. Finally, will an LX starter bolt up? It struggles a bit on startup so I might as well. I have a 2 week old one it the other car. I'm swapping the whole regulator out thursday, we'll see how that goes.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    hmm could be bad battery connectors cause my car does this and i have to move the cable a bit for it to turn on and if not might be the battery that cant handle the cold i had a problem with a battery that wouldnt work in the cold for shet check those 2
    SEi User dacantu's Avatar
    Jan 2009
    Phoenix
    It should bolt up but both cars have to be either automatic or 5 speed. Because the starters from an automatic aRe different to those from a 5 speed.
    Hope you get it all sorted out. I would think its weak terminals though
    -dan
    Feb 2008
    Now it wont respond to a boost, it did earlier this morning. I get what sounds like a dead starter click... lol, my boss will shit a house when he sees me working on the car out front
    Feb 2008
    I've had the exact same battery before, made it through the whole winter without a hiccup.
    Jan 2009
    Phoenix
    It could be your wires from your battery to your starter. check if they are loos on the battery or on the starter and also is your car a automatic? or 5 speed?
    if its automatic and youve checked the wires then try banging on the stater a little bit with a long metal tube and light hammer. it might just not want to turn over.
    if its 5 speed im sure you know you can push start it.
    but what it sounds like is just loose or old cables going to the starter because you said its like the juice is sucked out of the batt.
    -dan
    Feb 2008
    Well, thats actually not too bad. I'll check all my grounds tomorrow, replace my terminals, and see whats up. Its an auto, by the way. I dont suppose I can get away with 6 AWG wire for grounds or positive to starter wire can I? I have soo soo much of it.
    Jan 2009
    Phoenix
    Yes im sure that will be fine temporarily. I'm planning on redoing all my grounds soon and I will use 4awg or even 2awg. but bigger than 4awg is absolutely not necessary.
    -dan
  1. Cold and Hot?
    By osmialo123 in forum 3geez Accords
    Last Post: 02-11-2005, 10:58 AM
  2. Cold Can
    By RobbyKlotz in forum Carburetor Tech
    Last Post: 06-26-2004, 12:43 AM
  3. more air or cold air
    By 1988_5spd_lxi in forum Performance
    Last Post: 12-03-2003, 09:06 AM
  4. hot-cold-hot-cold-hot-cold
    By jlaccord89lxi in forum 3geez Accords
    Last Post: 09-04-2002, 05:11 PM
  5. CAI w/o cold air(?)
    By 1989se-i in forum Performance
    Last Post: 08-25-2002, 08:20 AM
