View Poll Results: Vote for 2009 Accord of the Year
Voters
73. You may not vote on this poll
  • 3gmodifier
    3 4.11%
  • LX-incredible
    8 10.96%
  • Pico
    3 4.11%
  • Tdurr
    5 6.85%
  • 87roach
    5 6.85%
  • JOSEAMOY
    5 6.85%
  • Turabaka
    2 2.74%
  • RendonLXi
    11 15.07%
  • thegreatdane
    17 23.29%
  • Tommy AC89 Thailand
    4 5.48%
  • A18A
    6 8.22%
  • 84Accord
    4 5.48%
Results 1 to 13 of 13
Thread: Accord of the Year Voting - 2009
    87accordlxi's Avatar
    Oct 2000
    87 Accord (RIP), ND Miata
    Santa Ana, CA
    Here are our AOY nominees from the past year. There are a number of pictures in this thread, and they may take some time to load, even on fast connections. The winner of this poll will be our Accord of the Year, so PLEASE take your time and vote for the vehicle that you truly feel deserves to win.
    Just as in the AOM voting threads, THERE IS NO POSTING ALLOWED IN HERE. JUST VOTE.
    This poll closes on January 1st.
    AOY Rules
    - Joe
    Oct 2000
    Santa Ana, CA
    Re: Accord of the year voting - 2009
    3gmodifier
    engine:
    jdm b20a (blacktop) with manual tranny ph3 ecu
    black powdercoated block and tranny
    refinished valve cover
    battery and box in trunk
    shaved engine bay with 100% wire tuck
    relocated all brake lines
    msd sci-l
    blaster ss coil
    nkg iridium plug
    modified stock short ram intake
    interior:
    swapped dashboard ( now dark charcoal, used to have marroon interior)
    jdm digital climate control( fully operational)
    jdm map light
    3rd gen prelude seats
    fully re-uphostered doors, headliner, rear quarter panels.
    3rd gen prelude steering wheel
    1st gen accord shift knob
    re-upholstered rearshelf with shaved speaker mounts
    made a new trunk panel and upholstered it
    exterior:
    super clean body prepped to a satin finish
    front and rear mudflaps
    custom front lip
    jdm bumper pole
    jdm fog lights
    jdm side markers
    jdm corner lights
    jdm rear spoiler ( not duck bill)
    jdm power folding mirrors
    jdm rear fog lights ( not installed yet, need a new rear bumper)
    h4 conversion
    6000k hid's
    suspension:
    ground control coil overs
    kyb gr2 shocks
    camber kit front and back
    all new wheel bearings
    oversized rear sway bar from acura vigor
    rear disc brake conversion
    16'' rims with yokahama rubber
    electronics:
    kenwood touch screen dvd player
    infinity componate speakers up front
    infinity 2 ways in the rear
    infinity kappa perfect 12's
    infinity referance 1211a 1300w amp
    kinetic 100 fared battery capacitor
    crime stopper 2 way alarm with remote start( wired to activate folding mirrors on arm/disarm)
    custom relay operated ecu/fuel pump killswitch
    push button start only ( removed wire completly from key assembly, hot wire proof)
    i am sure there is some stuff i missed. there has been so much. i need to uplad my new pics of the lip and other stuff. this pics are a little old but its all i have at the moment. i will update.
    - Joe
    Oct 2000
    Santa Ana, CA
    LX-incredible
    Engine
    • A20A3, semi-rebuilt.
    • Toga HP oil pump.
    • EGR and cold idle block-off plates.
    • Small coolant line deletion and vacuum line simplification.
    • New Accel injectors and new sensors.
    • Engine harness wired and waiting for obd1.
    • AEM Integra CAI with Dryflow filter.
    • NGK V-power plugs.
    Transmission and Drivetrain
    • 5 speed rebuilt, with 1st gen Integra internals and Accord 5th.
    • LUK Repset clutch (slightly stiffer than OEM).
    • Skunk 2 88-00 Civic short shifter with aluminum shift knob.
    • Prothane 84-87 Civic shifter bushings.
    • New axles, wheel bearings, and hubs.
    Exhaust
    • DC Sports header.
    • 2.5” Areo Turbine resonator.
    • 2.5” Magnaflow spun metallic catalytic converter
    • 2.5” Magnaflow performance muffler.
    • 2.5” stainless mandrel bent exhaust, collector back, painted with VHT ceramic black paint.
    Suspension
    • Rebuilt 2g Accord manual rack and full power steering removal.
    • All polyurethane bushings in front except UCA bushings.
    • All poly bushings in rear except upper shock and trailing arm bushings
    • All new ball joints, control arms, and remaining OEM bushings.
    • Front and rear ST sway bars.
    • Eibach Sportline 1.5” lowering springs.
    • Bilstein HD shocks.
    • Moog front camber studs.
    • Ingalls Smart Arm rear camber adjuster with poly bushings.
    • DC Sports front strut tower bar.
    Brakes
    • Rebuilt front calipers
    • SE-i rear disc swap, all rebuilt or new parts.
    • Front and rear Brembo Sport drilled rotors.
    • AEM brake pads.
    • Techna-Fit SS brake lines.
    • New master cylinder.
    Wheels and Tires
    • Civic HX 14” lightweight wheels.
    • Michelin Destiny P185/70R14.
    Weight Reduction
    • AC, PS, cruise control, and power antenna removal.
    • Odyssey drycell battery with custom bracket.
    • Trunk lining and center console removal.
    - Joe
    Oct 2000
    Santa Ana, CA
    Pico
    Engine Specifications:
    Fully rebuilt A20A3 engine, Std.Rod and Main Bearings, Block bored out to 20 Over.
    Delta 272 Camshaft
    Golden Eagle Adj. Cam Gear
    Bosch 4th Gen. Fuel Injectors
    Blox Fuel Pressure Regulator
    VISION Motorworks Fuel Pressure Guage
    NGK Iridium Spark Plugs
    8.5mm MSD Wires
    MSD Blaster 2 Coil
    MSD 6A
    Custom 2.5in CAI
    AEM ByPass Valve
    Battery Relocated to trunk /2ga Wire
    Optima Red Top Battery
    135 amp Alternator
    Alternator Direct wired to Battery
    Big 3 wiring Done
    Removed A/C and Cruise Control
    Replaced stock cooling fans with 2 Hayden 800CFM Electric Fans
    Koyo Radiator
    Exhaust:
    Pacesetter Ceramic Coated Header
    2.25 Pipe from the cat. back
    Magnaflow Muffler
    Magnaflow Resonator
    Magnaflow Cat.
    Stainless Steal Tip
    Drive train:
    Swapped from Automatic Transmission to 5 speed Transmission
    Exedy Clutch
    Energy Suspension Shift Bushings
    Suspension, wheels & tires:
    SRX Rims 15x6.5 12.5lbs
    Kumho ECSTA AST Tires 205-50/15
    Front & Rear Tokico HP Shocks
    Front Trustar ceramic brake pads
    Front Brembo Rotors
    Front & Rear SUZUKA Stainless Steel Brake Braided Lines
    Justin Front Strut Bar
    Justin Rear Lower Bars
    Gold-Line Springs 2.25 Drop
    Energy Suspension Polyurethane Sway Bar End Links #9.8105g
    Energy Suspension Polyurethane Sway Bar Bushings #9.5158g
    SuspensionTechniques 5/8" Rear Sway Bar
    Interior:
    Prelude Steering Wheel
    Black Prelude Seats
    EQUUS Oil Pressure and Voltage Gauges
    Alfa Otto Reverse Glow Gauges
    OE fog lamp switch
    Center Armrest
    SEI Cupholders
    Skunk2 Shift Knob
    Pilot Shift Boot
    JDM Maplight
    Black and Burgundy Interior (Black dashboard, Upper Door trim black to match dash,Black Center Console and Armrest, black accents thru out the car)
    Stereo:
    Deck: Alpine CDA-9851
    Doors: MTX 5 1/4 TDX-5202
    Rear: Kenwood KFC-6959ie 6"x9" 2-way Speakers
    Power: Profile AP400 65ws x 2 Car Amp Bridged to the 10in Sub/ 8gauge power wire
    Sub: Sony Xsl101P5 10in SubWoofer
    Box: Q-Logic QLH-.6510SS Single 10 Box
    Satelilite: Alpine XM Direct Adapter
    Misc. 40gb iPod
    Exterior:
    Hella H4 Headlamps
    Sylvania SilverStar Bulbs
    Bitesize LED sidemarker bulbs
    JDM Corner Lamps
    Clear Turn Signals
    SilverStar Turn Signal Bulbs
    89 Integra front lip
    Hella Optilux 1100 Fog Lamp Kit
    OEM Window Visors
    Front Door Handles Replaced With Sedan Rear Handles
    - Joe
    Oct 2000
    Santa Ana, CA
    Tdurr
    Mods
    *Engine
    * Rebuild +20 overbore
    * Pacesetter headers
    * 2.25in exhaust w/high flow cat
    * MSD Coil Pack
    * CAI
    * Delta 272 cam
    * NGK Plugs+ Wires
    * Painted VC
    * Removed AC+lines
    * removed Cruse Control
    *Outside:
    * 17in ASA rims
    * Tinted Tails
    * Tinted Front turn signals
    * Legend front lip
    * Domo, ImportAlliance, and Megan racing stickers
    *Interior:
    * Dyno matt cab(minus doors)
    * Recovered seats(4g worth of leather)
    * Moded dash for 7in Tv
    * Oil Pressue, + A/F Gauges
    * Pedal Cover
    * 2 10in subs
    * Gutted trunk besides subs+tools
    *Suspension:
    * Tokico blues + Ground Control sleves(rear)
    * Unknown struts + ebay sleeves(front)
    * Lowered around 3in.
    * Rear strut Bar from a cb7(Megan racing)
    * stock sway bars(for now)
    *Other Mods:
    * Rear disk conversion
    * Slotted(front) & Drilled(rear) rotors
    * Battery moved to the rear
    * Power Coated VC
    * and some other things i cant think of...
    - Joe
    Oct 2000
    Santa Ana, CA
    87roach
    Stock Specifications:
    1987 Honda Accord Hatchback S (Canadian model)
    A20A1 2.0 Carb
    5 Speed Manual
    Polar White paint with maroon interior
    Engine:
    Carb to EFI conversion. (rebuilt a20a3)
    Block has been bored .50 over, new pistons, rings and pins
    Crank was ground and polished, rod journals .30 over, mains .20 over(new bearings for all)
    New seals, gaskets and frost plugs
    Head milled .05
    New water pump, timing belt
    Colt Cam Triflow stage 1
    GE cam gear
    New exhaust valves(1mm over) + valve job
    New thermostat
    Full port and polish
    Custom CAI with an AEM Dryflow
    NGK spark wires with iridium plugs
    Stock pulley machined to 1 journal
    New rad, all new hoses
    New paint on engine and valve cover
    No EGR
    Exhaust:
    Pacesetter header(ceramic coating)
    Full custom 2.1/4" with mandrel bends
    Magnaflow cat & muffler
    Cherrybomb glasspack
    Drive Train:
    Poly shift bushings
    Skunk2 Pro S Full Bodied CO's
    Suspension Techniques F/R sway bar with poly bushings
    All new wheel bearings, ball joints, bushings, tie-rods/ends
    Prelude adjustable control arms
    Everything blasted with new paint
    Drag DR6 17x7 Gunmetal wrapped in Falken 452's 205 40 17
    Brakes:
    All new calipers, rotors, and pads
    SS brake lines all around
    Rear disk swap
    All freshly painted
    Interior:
    Se-i interior swap(charcoal)
    Power window swap
    Prelude seats, charcoal
    Momo Jet2 steering wheel/hub
    Momo DNA pedals, simple black
    Razo 270mm convex mirror
    Whole cabin lined with 150sq of B-Quiet Ultimate
    Exterior:
    15% Tint on the back 3
    35% Tint on the doors
    86-87 JDM front lip (rare)
    Comming soon:
    MSD Ignition
    OBD-1
    New audio system
    Misc:
    New paint on lots of things
    Replaced just about all hoses, lines, filters, seals, ect.
    Pics:
    - Joe
    Oct 2000
    Santa Ana, CA
    JOSEAMOY
    Honda Accord 1981
    100% stock
    - Joe
    Oct 2000
    Santa Ana, CA
    Turabaka
    1988 Honda Accord Hatchback DX
    • 38 Weber Carb
    • Delta 272 cam
    • ported intake manifold
    • MSD blaster 2 coil
    • Accell super stock 8mm wires
    • Optima red top starting battery
    Fuel & Tuning:
    • Holley blue fuel pump with regulator set to 3psi
    Exhaust:
    • Pacesetter header
    • 2.25 inch mandrel bent exhaust
    • Magnaflow cat and muffler
    Drivetrain:
    • Pacesetter short throw shifter
    Weight reduction & transfer:
    • stripped carpet and sound deadening
    • full vac removal
    • Tokico blue shocks
    • Sprint springs
    • Acura Vigor rear sway bar
    • 2g prelude front upper control arms
    • SE-i disc brake setup
    • 215/45-16 Falken Azenis tires
    Interior:
    • stripped carpet
    • sunpro water temp, volt, and oil psi gauges
    • indiglo gauges for tach, speedo, and temp
    • Corbeau fx1 pro seats
    • TeamTech 4 pt camlock harnesses
    • Custom harness bar
    Exterior:
    • 20% tint all around
    - Joe
    Oct 2000
    Santa Ana, CA
    RendonLX-i
    Engine Specs
    Fully rebuild A20A3 /9:1 compression
    B&M Fuel pressure Regulator
    8.8 Accel spark plug wires
    NGK G-powers
    4Gen Accord Map Sensor
    Delta Camshaft 272
    GoldenEagle CamGear (not Installed)
    Mallory 6AL/ SS blaster coil
    Custom Ground kit
    93 Civic Racing Radiator
    12inch Slim Fan
    DC strut bar
    Ebay Catch can
    Turbokit
    Dsm T-25 2gen .48 trim internal WasteGate
    SMIC 2g DSM
    Custom Charge pipes
    Custom Log Type Manifold By (JUSTIN)
    HKS SSQV Bov
    450cc Blue Tops Controled by S-AFC
    2.5 Inch downpipe to 2.1/4 catback
    Greddy Full Turbo Timer (not Install)
    Tuner Toys StealhMode Oil line kit
    Turbox manual Boost Control (not install)
    Autometer: Boost,Air Fuel Ratio, Oilpressure Gauges
    Suspension
    Kyb Gr-2
    Eibach Sportline 2.5inch drop
    Del Slow SwayBar Bushings
    Vigor Rear Swaybar
    SS Braided Brakelines
    Powerstop Rotors
    93 accord Lower tie bar
    Ingalls camber kits in front
    Rear Adjustable Camber kits in back
    All Rolling in Motige Trak Lites Wraped in 205/50/15
    Dulops Dz101 Drag Radials
    Interior
    Nopi Reverse Indiglow Gauges/ Bezel
    All Stock interior
    PaceSetter Adjustable Short Throw
    JDM Real type R Shifter Knob
    SEI ArmRest
    3g Lude Seats
    3G Lude Steering Wheel
    The Knocks
    Phoxian Gold 1000watt 4 Channel
    All 4 Componet MB QUARTs
    Kenwood Amp 2 channel Mono Digi
    2 12 kenwood Swirl subs
    2gauge wire kit
    power cap
    Indash 3.5 power acustic dvd/vcd/cd/mp3/player only running Amps not off the stereo
    9.2 Flip Down Screen Boss
    Exterior
    Si Blue paint w/ a hite of purple
    lazey pearl
    87 Crx si Clear Bumper lenses
    custom rear bumper with mesh
    Maxspeed Turbo muffler
    93 Accord Front lip
    HID H4 Conversion kit w/ 6,000k
    Hella H4 Housings
    Battery Relocated kit
    - Joe
    Oct 2000
    Santa Ana, CA
    Tommy AC 89 Thailand
    Modification and Specification of my CA5
    Exterior
    • Painted all of the car with lemon green pearl colour.
    • URAS drifty style bodykits custom made in Thailand from fiberglass.
    • JDM folding mirrors
    • VIGOR trunk and rubber duck tail from VIGOR 89 Japan spec.
    • Orange side marker lights from Accord 95 SiR Japan spec.
    • Red side marker at rear bumper from Accord 95 Japan spec.
    • Cefiro A31 diamond clear light at front bumper.
    • Swap new headlights and painted with black and yellow inside the headlights.
    • Blue HID light bulbs.
    • Adjustment number plates.
    • Weather guard from Accord 89 Japan spec
    • Bride lock hood.
    • Windshield wiper with out yoke.
    • Honda of America emblem.
    • Red H emblem.
    • Mega Shield 40% Brown tint.
    Interior
    • Console and interior and rear seat with brown colour swap to Accord 89 Japan spec.
    • SPACO PRO 2000 bucket seat on driver seat right hand side andSabelt racing safty belt.
    • Toyota MR-S seat on passenger seat left hand side.
    • Sabelt steering wheel drifty style and Momo horn button.
    • ELEVO enging start button.Accord 95 White Colour dashboard Japan spec.
    • Pivot stepping gauge.Hericane Floor strut bar.
    • Trust shift knop.
    • Type R aluminium paddle.
    • Relay break switch.
    • Pioneer CD MP3 player. (also have JDM stock radio
    • Kicker lound speakers.
    • Sard ballfix flipper steering wheel.
    Engine
    • Swap H22A from Accord SiR 1995 Japan spec
    • Painted in red cover valve.
    • Maxspeed spark wire and spark plug.
    • Blue aluminum intake manifold.
    • Stainless steel air filter.
    • D1 Volt stabiliser
    • Evil earth ground wire.
    • Spec radiator cap.
    • 2 level radiator.
    • DC front strut bar.
    • Mugen engine cap.
    • Pivot Fuel Magnetic
    • Stainless muffler custom made in Thailand.
    Suspension
    • Pressure pot 1 1/2 level from Accord 93 Japan spec.
    • R-racing shock absorber.Accord 95 SiR front break Japan spec.
    • Accord 89 rear dise break Japan spec.
    • Rear strut bar from Japan.
    • Aluminium spacer 1" on rear wheels.
    • Racing nut logs.
    • Lenso wheel 17"
    • 7" same size 4 wheels painted in yellow colour.
    • Hankook V8 tires 225/45/17" same size 4 tires.
    - Joe
    Oct 2000
    Santa Ana, CA
    thegreatdane
    Engine:168.3hp and 184.6Nm (136lbs/ft) torque
    H22A DC Sports header, modified to fit and ported to match B20A ports. Collector replaced with a 2.5" collector instead of that pos 2" they are made with
    2.5" custom stainless exhaust straight through with a Simons silencer and a Magnaflow muffler
    B16A2 intake manifold
    B18B distributor and custom block-off plate at exhaust cam
    B&M fuel pressure regulator
    Crower stage 2 B18B cams
    Valve cover painted white
    Black box removed
    Fuel & Tuning:Converted to OBD1
    P06 ecu converted to P28 and chipped
    Boomslang 3rd gen Accord OBD0->OBD1 conversion harness
    VSS sensor 6k resistor mod
    Ostrich rom emulator
    USB datalogging
    Innovate LM1 wideband
    Crome Pro tuning
    Suspension, wheels & tires:Koni red struts front and rear
    Ground Control coilovers
    DC sports front strut bar painted white (not installed currently, there's no room for it with the B16A2 manifold)
    17x7" Kosei Sniper rims w. Falken tires.
    Interiorigital gauge cluster from RHD CA3 Accord
    Auto-Up drivers side window switch mod
    Exterior:New paint job in summer 2005
    JDM power folding mirrors painted silver like the car
    JDM CA headlight turnsignals - replaced the ugly dummy lense reflector
    Removed small round front fender turnsignals
    Door handles painted silver like the car
    Badboy look welded to the bonnet
    - Joe
    Oct 2000
    Santa Ana, CA
    A18A
    - Carb > PGM-FI Conversion
    - Auto > Manual Conversion
    - A20A > B20A Conversion
    - Cleaned up engine bay
    Suspension/Brakes:
    - Rear disk brakes
    - Twin piston front calipers
    Exterior:
    - Replaced front bumper
    - Custom JDM tinted CA Bumper lights
    - OEM fogs
    - 13" Alloys
    - Swapped front & rear number plates
    Interior:
    - Digital Climate Control Conversion
    - Useless switches
    - NZ New stereo
    - Colorful gauges
    - Alarm
    Soon to come:
    - 15" wheels
    - A good service
    - Sounds
    - Lowering
    - Joe
    Oct 2000
    Santa Ana, CA
    84Accord
    84' lx hatch
    Engine
    - stock ES2 with 240,xxx miles on it
    - replaced cam
    - replaced carb
    - replaced clutch
    - flipped lid
    - Racing radiator with electric fan
    -2.25" exhaust from header, to magnaflow high flow cat, mini turbo mufller
    Exterior
    - custom 2 tone paint (black cherry bottom and silver top)
    - 17" ADR sokudo rims
    - Falken tires
    - front slotted rotors with competition pads
    - FOHA rear spoiler
    - Vestatec Front Bumper
    - H4 Conversion with HIDs
    - front and rear benen tow hooks
    Interior
    - 5% tint
    - Driver and Passenger Sparco seats
    - changed carpet to black
    - custom armrest from a 3g
    - MOMO jet steering wheel with NRG quick release
    - sound deadening under carpet
    - custom headliner
    - paging alarm
    - Removed spare tire and carpeted rear
    Sound
    - Sony HU
    - 2- 5 1/4" alpine type s speakers
    - 4- 6 1/2" alpine type s speakers
    - 800 Watt sony xplod amp
    - 2- 10" jackhammer subwoofers in custom box
    and heres some of my recent pics from the meet at picos house on sunday
    - Joe
  1. 2009 Accord of the Year: thegreatdane
    Last Post: 11-09-2011, 12:28 AM
  2. ACCORD OF THE YEAR Voting - 2008
    Last Post: 11-28-2008, 09:01 AM
  3. ACCORD OF THE YEAR Voting - 2007
    Last Post: 12-03-2007, 06:12 AM
  4. Accord of the Year - FINAL VOTING THREAD
    Last Post: 12-15-2006, 12:05 PM
  5. ROUND 1 Accord of the Year Voting - Coupes
    Last Post: 11-28-2006, 08:59 AM
VigLink badge
