Results 1 to 12 of 12
Thread: fuel pump trouble
    LX User beran24's Avatar
    Apr 2008
    1989 Honda Accord dx 2dr, 1989 exi, 87 hatch
    Nova Scotia Canada
    fuel pump trouble
    ok so the exi i got wont start. Took a few mins today and pulled the wires off the fuel pump turned the car on checked with a test light no power at the pump. Then checked at the fuse no power there ether. My conclusion is broken wire some where. Just wonderin the clutch saftey switch wouldnt matter if it was in or out i should still have power at the fuel pump right? cus when i tested the clutch wasnt shoved in but thats not wired with fuel pump is it.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: fuel pump trouble
    are you sure you didnt pull on fuel pump wires?? maybe causing a short somewhere...look around the fuel tank if the cable is plug in and check yo fuse if not that check the relay fuse
    Apr 2008
    Nova Scotia Canada
    i unplugged the wires from the top of the inspection hole to test for power, the fuse is good, could you tell me the location of the relay fuse? thanks. if this is all good ill start looking for a short in the wire
    Oct 2009
    its behind the fuse box it should be a bronze looking one (you see fuses there should be 3 or 4 relays) check to see if your getting power from the main if its out go to the junk yard and get them dont go to any auto store unless you wanna pay 50$$ for one
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    check the main relay. turn key on should click once. then when lights on dash go out should click again. Lemme see if i can find something.... k
    http://www.pauldesign.ru/honda/shopmanual.html
    in the manual under fuel and emissions 12-67 that should help
    you can test the wiring from the relay to the pump there
    Apr 2008
    Nova Scotia Canada
    so i went out today after school and got the relay out. I'm gonna test it tomorrow if i have time. JUst wondering to test it all i need to to is hook it up to a battery on the conectors it says in the book then hook a test light on the other conectors?
    Apr 2008
    Nova Scotia Canada
    tested the main relay when i hook the power to it from the battery like it says in the repair manual to test it. It makes a click. then i run the test light from one conector to the other on all 3 tests that it says to do and there is no light come on so i think thats my problem. headin to the jy to pick up anothr one soon
    Oct 2009
    Alright man good luck and only go to a store for a last resort if you have no luck
    Quote Originally Posted by beran24 View Post
    do you know how to resolder it? 99 percent of the time the solder connections come loose. it's easy to fix, if you get another one,send that one to me and i'll fix it for you, won't take but a few minutes. then you'll have a spare.
    I'd buy that part new myself. They're known to fail quite often on these cars. As hard as they are to get to, why fool around with a used and likely faulty one? Just my $0.02.
    Apr 2008
    Nova Scotia Canada
    i'm not gonna bother tryin to fix it but thanks anyway
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Brother you said.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
  1. Fuel Assembly , Pump , & Fuel System Location
    By A20A1 in forum Carburetor Tech
    Last Post: 05-10-2016, 01:27 AM
  2. Fuel Filter? Fuel pump?
    By Bass Man in forum 3geez Accords
    Last Post: 05-19-2008, 03:38 AM
  3. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
  4. fuel pump
    By nappyroots827 in forum Performance
    Last Post: 11-20-2004, 06:30 AM
  5. fuel pump?????HELP!!!!!!!!
    By jay1988lx in forum Carburetor Tech
    Last Post: 05-19-2003, 03:28 PM
