Results 1 to 7 of 7
Thread: 89 SE-i weird idling issue
    Tennessee
    I did a search on this and came up empty handed. I have an auto 89 SE-i coupe. When I start it up, the first crank is no good (held for 3 seconds), then the second crank works (2 seconds) but I smell tons of fuel. I was thinking it could be the TW sensor. But to add confusion when cold, the RPMs are steady at 1500, then once the engine starts to warm, the RPMs smoothly drop down to 850-900. As long as I don't touch the throttle, the RPMs settle in perfect, but once I touch the gas they stay up around 1500 with no fluctuation. I have adjusted the TV and the throttle cable, and made sure it wasn't too tight. Even when I put my foot under the gas pedal and pull up, the idle stays the same, this also happens when driving. Any ideas? Below is the only thing I can come up with:
    TW Sensor faulty
    Vacuum Unit
    1989 Accord SEi Coupe
    04 Infiniti G35 Coupe 6MT
    07 Honda CR-V 4WD/Nav
    Tennessee
    Re: 89 SE-i weird idling issue
    By the way, I don't have a check engine light when this happens. I only get a check engine light on longer drives (30 minutes).
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    check for codes in the ECU (under the drivers seat)
    Sep 2009
    86 Accord LXi 5sp, 293k
    Montgomery, AL
    Welcome. Check for the codes. The computer is under the drivers seat.
    https://www.3geez.com/forum/showthread.php?t=26342
    May 2008
    los angeles
    could be a stuck fast idle valve
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    Tennessee
    Thats actually what I was going to check today. The idle never bounces up and down, but maybe once more vaccuum is applied, the fast idle starts to stick.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Just about any sensor going bad could produce that symptom. I saw it when my TW was going bad and again when an O2 sensor was going bad.
    Mike
  1. Idling issue, please help!!!!!
    By logan9691 in forum Carburetor Tech
    Last Post: 03-06-2013, 11:06 PM
  2. Weird Idling issue
    By Gt-r in forum Carburetor Tech
    Last Post: 08-28-2012, 09:03 PM
  3. idling and engine issue
    By panthere0rose in forum 3geez Accords
    Last Post: 06-08-2012, 08:27 AM
  4. idling issue, hot engine (Weber)
    By TotaledTL in forum Carburetor Tech
    Last Post: 01-02-2012, 06:27 PM
  5. Idling Issue....
    By New3rdGenOwner in forum EFI Tech
    Last Post: 04-05-2008, 10:12 AM
