Results 1 to 22 of 22
Thread: Have any of you tried cleaning out the Idle Air Control Valve on these cars
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    It does not work on every IACV on all cars. But these seem to be very basic ones. Started to get a rough stumble at start up then the fast idle valve takes over and then warms up drops down and runs fine. It is the IACV. They get carboned up over time and can cause these symptoms. You must use a carb cleaner that will not harm 02 sensors ( Because of the probe inside the IACV operates the same way). So has anyone tried it on these with success?
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    SE-i Sedan 5 spd
    Re: Have any of you tried cleaning out the Idle Air Control Valve on these cars
    That part isn't the IACV from our cars is it? It doesn't look like it, or as I remember it anyway. What I DO remember is what it took to connect the coolant hose from the valve to under the intake manifold. I couldn't do it, and my mechanic said he used up his daily ration of cuss words on the job.
    Apr 2009
    Orange County Cal.
    Quote Originally Posted by w261w261 View Post
    That is the back view that mates to the manifold. So you can see the plunger inside. I just am curious if anyone has done it on here. Here is the front view that should look more familiar.
    Dec 2003
    Millington, TN
    Yeah, you have to clean the coolant chamber on the bottom as well.
    Phil
    Apr 2009
    Orange County Cal.
    Quote Originally Posted by nswst8 View Post
    You have done it and had good results?
    SE-i Sedan 5 spd
    Maybe this is something I should consider, but I guess I'll wait until I have an issue. I just replaced the two little coolant hoses. OTOH, it looks like it comes off easily, so maybe a candidate for preventative maintenance.
    I've had zero idle problems in the 8 years and 140k miles I've had the car. Maybe I'm fortunate?
    Dec 2003
    Millington, TN
    Yes, it helped.
    Phil
    SE-i Sedan 5 spd
    I imagine the gaskets are available from Honda?
    Dec 2003
    Millington, TN
    Gaskets were not completely bad, I just added some gasket sealant Blue RTV sensor safe.
    Phil
    May 2008
    los angeles
    i had a stubling idle once... the iacv was completely blocked and full of carbon... swapped it out for a used one (in better condition) and it worked fine... but as far as cleaning goes... i just used soap and water and it works fine even for the water jackets on the bottom.. be sure not to get the electrical wet or youll have problems til the part dries
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    DX User Layson's Avatar
    Apr 2008
    Corvallis, OR
    I have a weird idling issue when it starts up... the RPM's bounce up and down for a while, then smooth out. Would this be a cause for that?
    Where the heck is that at on the motor?
    87 Hatchback Lxi - 294,000 miles - 5 Speed
    ^^if your car is an 87 it may not even have one iacv is 88-89 only but you will have a fast idle valve which will be causing the rev bouncing its on the back of the intake manifold with a cap and 2 screws holding it on.
    Apr 2008
    Corvallis, OR
    Didn't know that. I will have to see if I can find that...
    Apr 2009
    Orange County Cal.
    Cleaning it did not work for me. It will either rarely work or get worse on a 22 year old part.My got worse ( barely idled after cleaning and drying for days) So since I did alot of work on the car the past few days, I decided to splurge and get a brand spankin' new one. I tell you it is a beautiful thing. No minor stumble at start up and idles as the day it was born. It was worth it to me.
    LXi User -$MOKIN-'s Avatar
    Apr 2006
    1989 HONDA ACCORD LXI
    Where is this valve located im gettin a code 14 for some reason today
    middle of the intake manifold. Has a 3 ? pin connector and 2 coolant lines hooked to it. I have had to loosen the lines and get air out there that the bleeder would not.
    That's a great idea. I have resorted to jacking up the front of the car, but I'm still getting some idle bounce when cold.
    May 2008
    los angeles
    the cold start issue might be the thermovalve on the manifold... i blocked that one off and the iacv and it was good... cold starts were a bit low on the rpm scale but when it warmed up it idled like a champ
    -Tom
    Aug 2008
    1987 honda accord lxi hatch
    lincoln
    that picture is not the valve for our accords thats probabaly off a civic and yes if you clean it out it helps.
    and if your revs are bouncing its because the thing on the inside got loose and all you have to do is tighten her back up and clean the inside and your problem should go away.
    and its located right next to the throttle body on back of the intake 3 bolts hold it on and two coolent hoses on the bottom.
    Apr 2006
    Danny that is it bro .....It only on a 88-89 .home slice..
    And thanks for the bleeding idea. Ol BlUE YOUR THE MAN
    Aug 2008
    lincoln
    WOOOOOWWWW!!!!! i cant believe i forgot about the dual air flow intakes haha
    sorry guys i forgot.
    Jul 2009
    Somerville, Alabama
    I cleaned mine out with a set of dental picks and sensor safe FI cleaner. Took an hour or so. I filled my IACV up though with FI cleaner to the brim and let it sit until it evaporated and it made it like 100X easier to scrape it all clean. Just be very gentle with the pick. And save yourself like 2$ from honda and O'Reilly's has a perfect fit oring for 42cent(When i bought it a year ago)
    Shaggy
    FF II/ETC I
  1. Air idle control valve
    By -$MOKIN- in forum 3geez Accords
    Last Post: 08-03-2011, 07:03 PM
  2. Report: vacuum advance + fast idle valve cleaning
    By AC439 in forum 3geez Accords
    Last Post: 02-01-2009, 04:42 AM
  3. Idle Air Control Valve hoses
    By w261w261 in forum 3geez Accords
    Last Post: 10-18-2007, 11:58 PM
  4. [Engine & Transmission] Idle Air Control Valve (Code 14 on EFI cars)
    By Knowledge Base Admin in forum Frequently Asked Questions
    Last Post: 04-29-2002, 02:04 PM
