Results 1 to 6 of 6
Thread: weber carb
    DX User geej07's Avatar
    Sep 2008
    87 accord lxi rip. 88 lx 89 lxi parts car
    zanesville ohio
    weber carb
    i was reading an every one was talking about a kit for there weber carb. so do they make a kit to bolt a weber carb on the accord or do they just make one size or what. i was looking around on ebay an seen one for a landrover an nissan that was it. so if anyone could help me out that would be great!
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: weber carb
    check redline weber. most people run one of the two sizes, 32/36 or the 38/38.
    the 38/38 isnt really needed unless ya do a few other bolt ons tho...
    Re: weber carb
    Having used either, I would prefer the 38.. it made the most difference but manifold & adapter need dremel or rotozip work to open them up some and remove the partition.
    32/36 is more of the bolt on and makes a world of difference too, just do it!
    carbs unlimited sells them online
    Sep 2008
    zanesville ohio
    Re: weber carb
    i found a 32/36 is it? on redline for 350 but i didnt see any 38/38s for the accord. ill prolly just get the 32/36.
    Re: weber carb
    they do not sell the 38 like that but you can use it by getting just the adapter plate for the 32/36 and just order the 38 by itself. Get a 38 with standard jetting for an app such as any 2 thru 2,6 liter 4 cyl., this will run ok but you want to get some extra idle jets in the.45 to .60 range for tuning.
    Of course there are more tuning tricks with main and air correction jets and other things but for starters idle jet tuning you will need to suit your regional temperature and car set up etc..
    There is a LOT more info on this here
    https://www.3geez.com/forum/showthread.php?t=4223
    LX User Xaisk's Avatar
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    Re: weber carb
    Im going with a 32/36 myself. Im ordering it soon and im pretty hyped to install it and gut out some unneeded vacuum lines =D
  1. Weber 38 Carb
    By jwm1120 in forum Wanted
    Last Post: 10-20-2010, 12:51 PM
  2. weber carb
    By SlammedAccord89 in forum Carburetor Tech
    Last Post: 04-03-2004, 08:03 PM
  3. weber carb
    By SlammedAccord89 in forum Performance
    Last Post: 04-03-2004, 07:31 PM
  4. Weber Carb
    By Dallas&SarahsAccord in forum Performance
    Last Post: 01-05-2004, 02:20 PM
  5. NOT Weber Carb!
    By 87DX in forum Carburetor Tech
    Last Post: 05-09-2003, 02:45 PM
