So a few weeks ago I replaced the coolant temp sensor. and it fixed all my problems. until two nights ago. i stopped at kinkos for maybe 25 minutes, i get back in my car, start it up, and it sounds just fine, then it dies. i start it again, dies right off again. third time i start it, and give it some gas to hold it around 2k rpm as i back out of my spot. then when i go from gas to brake, it dies before i can get the clutch in, first gear, then get back on the gas. so i start it up, give it gas and pull into a spot and let off the gas and it died. so i sat there and tried to think what was up. eventually i just nutted up and drove home, making sure never to completely let off the gas, so i used the hand brake at stop lights so i could idle it around 1.5k. and i got it home, and i pulled into my driveway, let it idle without help, and it stayed going, but it was idling down around 400 rpm. normal is just about 1k. if the engine is cold, it starts and stays running, but thats only because when its cold it idles at around 2k to warm up. but if its not doing that, or having me on the gas a bit, it'll die.
so after hours on these forums, i cant find any similar cases. other than one, saying it could be the main relay. which, is possible, but i hear it click so i think my relay is fine. or the fuel pump, which i hear spin for around 2 seconds when i turn the key, so i think thats fine too.
my ideas:
-air filter dirty?
-water condensation in the gas tank?
-alternator going?
one other thing, the check engine light went off when i changed the sensor. but last night i checked the ecu flashing led. it still blinks 6 times. was i supposed to reset the ecu after i changed the sensor? why is it still flashing?
also, when i start the car i hear a belt squeeling under the hood. how do i tell which one it is, and could that be causing any problems that cause it to kill itself?
