Results 1 to 25 of 45
Thread: Thoughts on new manual transmission?
    I got my warranty replacement transmission last week. Instead of the '88-'89 E2R5 transmission, however, they sent me an '86-'87 A2Q5 transmission. I know the A2Q5 trans will bolt up and work just like an E2R5. I know the car has no value so accuracy in restoration will never count for anything, but still it bugs me to know that I won't have the right transmission in the car.
    Am I being way too much of a weinie? Does anyone know if the A2Q5 is better, stronger, lighter or anything that might make me want it over the E2R5? Should I call up the yard and ask for an E2R5 and take my chances that they won't have one?
    Thanks!
    Re: Thoughts on new manual transmission?
    TO me it was the same snooz. I think the final drive is alittle different but other then that strong wise and exc. is the same. So i wouldnt really worry bout it.
    Millington, TN
    I would call and ask why you weren't sent a E2R5. Although the A2Q5 is compatible it was replaced with the E2R5. If it was just the availability then let them know that you are willing to wait the extra time to get the E2R5. Honda put the E2R5 in there for a reason.
    Ask questions.
    Phil
    I have an a2Q5, it has a little bit better gear ratio I believe, the carb cars don't have the same horsepower so the lower gears are shorter I believe, as is the final drive, the end result should be better acceleration with the FI car.
    AZmike's Avatar
    Tucson, Arizona
    The FI cars have the slightly higher final drive ratio, but the difference is pretty small.
    Mike
    carb cars got the longer geared for mpg and efi cars got the shorter gears... i honestly liked my 88 lxi one better then my 87 carb one... was a little funner to drive
    The difference between my '89 LX-i (E2R5?) and my friend's '86 LX (A2Q5?) were pretty noticeable. Mainly, the gear ratio. Her car can pass 40mph in first gear, my car is screaming by 30mph.
    Both the A2Q5 and the E2R5 are FI trans, so the gear ratios would be the same, right?
    Oh, I thought one was the fuel-injected transmission and the other was the carburated one.
    I have an a2q5 factory and it's a carbed one. I used to have all the engine and transmission codes, i can't remember what i did with them
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    I searched around. Don't know if this helps you or not.
    Transmission code
    HONDA ACCORD-PRELUDE TRANS CODE
    TRIM/ YEAR/ SPEED/ CODE
    Accord
    1976-79/ 5/ GF with Plate
    1979-83/ 5/ GK
    1984-85/ 5/ GY and GS
    DX & LX/ 1986-87/ 5/ A2Q6
    DX & LX/ 1988/ 5/ E2Q6
    DX & LX/ 1989/ 5/ E2R6
    DX & LX/ 1990/ 5/ H2A5-1 33x62x22 Front Pinion
    DX & LX/ 1991/ 5/ H2A5-6 33x62x22 Front Pinion
    DX & LX/ 1992/ 5/ H2A5-7 38x65x22 Front Pinion
    DX & LX /1993/ 5
    DX & LX/ 1994/ 5/ P2A4 & P2A5
    DX & LX/ 1995-97/ 5/ P2A5
    LXi F.I./ 1986-87/ 5/ A2Q5
    LXi F.I./ 1988/ 5/ E2Q5
    LXi & SEi F.I./ 1989/ 5/ E2R5
    According to the post below you , you have a "DX & LX/ 1986-87/ 5/ A2Q6"
    which sounds about right as u have a 86 DX . pretty easy to get the last number mixed up tho...
    and Btw Snooz if there both LX-i trans there should be no difference and i would not worry about it .
    Aug 2007
    Honda Accord-cowl Inducted, 351 CI Police Interceptor Air Filter with high rise hood
    around Tampa Florida, Paradise
    Help! Get me out from under the rental car bill!
    I have a carbed '89 Accord LX A20A1 engine, serial number 3536572 with 5 speed manual transmission that has no sticker on it.
    The 5 speed manual transmission that came out of my car has 21 splines, and a pilot shaft end of 12/16" dia. (about 3/4") and a tip length of 3/8"
    I can see by the wear marks on my original transmissions pilot shaft that it had a fairly tight fit into a hole
    in the end of the crank.
    The last manual transmission I have had to pay return shipping on had a much smaller pilot shaft end around 9/16" dia. with 21 splines and a tip length of 1/4".
    It had a sticker on the bell housing that said A2Q6.
    The newly arrived replacement transmission (from a different company) has a pilot shaft end around 9/16" with 21 splines and a tip length of 1/4"
    Same as the 5 speed that I just sent back. It has no sticker at all. They say it is the correct
    manual transmission for my car, just like the other company said.
    I know the small pilot shaft will fit into the much bigger hole.
    I don't feel good about that amount of slop in the pilot shaft if this goes into the hole in the end of my crank.
    If It breaks after 6 months warranty, it will cost me another $600 plus shipping.
    Plus another rental car bill.
    What do I need to tell the transmission people so I can get the same pilot shaft diameter as the 5 speed manual
    transmission that was in the car?
    ---- spring/suspension installation help -mobile alignments -street lowering with your own stock springs...........
    Have a great day! [email protected] 813-839-4281 (24 hrs)
    Jeez dude. One thread is sufficient. Go put that trans in and get rolling.
    Aug 2007
    Are you saying that a person should put in a transmission that has 1/8" of slop around the pilot shaft?
    Won't that cause it to first wear out the front transmission bearing and eventually transmission failure?
    Not knowing if anyone would see my post at all in a thread that was years old, I found that a new post
    might be seen.
    I'm not sure what you are measuring, but any of these transmissions that were designed for the A20 will fit any other A20, the only differences are some of the internal gear ratios, the case, out put shaft dimensions etc are the same. This includes the A20 installed in the second generation prelude, the blocks and transmission cases are identical. Actually if you don't mind giving up a slight bit of gas mileage due to gear ratios, the most fun to drive ratio is in the second generation prelude ones
    Aug 2007
    Nothing against you man, NOBODY knows what I'm measuring. Including the people selling the transmissions.
    But if they can make plenty of money selling the wrong ones (which cause clutch chatter and eventual failure)
    to people over and over, why should they change?
    I'm trying to figure out specifically how I put a picture up on here.
    Aug 2007
    An A2q6 tranny has a tiny pilot shaft or input shaft 9/16" (barely larger than 1/2") and lots of slop when put into the hole in the end of the crank.
    An E2R6-020 has a 3/4" pilot shaft or input shaft and fits perfectly in the end of the crank.
    E2R6-020 is the tranny that was in the car. The engine that is in the car is A20A1
    Another tranny that may fit is an E2R5.
    There are plenty of my needed transmissions on shelves across this country and no one knows
    that they have them because they are selling enough of the tiny-pilot-shaft-doomed-to-fail ones.
    Aug 2007
    Ok folks, I'm telling you secret stuff that I am the only person in the US knows. 21 splines 3/4" diameter pilot shaft/input shaft, 3/8" long not counting tapered part.
    The dummy pilot shaft is the one that fits my clutch and into the end of my crank. specs are above. The tiny pilot shaft or input shaft on the tranny is what I was sent. that has slop in the larger hole that is in the end of my crank.
    Aug 2007
ID:	7196Click image for larger version.
    Quote Originally Posted by senor honda View Post
    I'm not doubting you, I'm just trying to figure out whats going on too
    Aug 2007
ID:	7197 You can see difference in size compared to the other pictures. Can you see how close the end of the smooth shaft comes to the splines. This pilot shaft or input shaft is tiny and has a lot of slop when in the hole in the end of the crank. The length of the smooth part is only 1/4 long compared to the one that came in the car length of 3/8". I don't know why the picture came upside down. If someone knows how to rotate it, feel free to do so.
    Mar 2003
    2004 Acura TL
    Arkansas
    Some had a pilot bearing, some did not. I'm guessing you need to install a bearing that your old tranny didn't need.
    When did 12/16" become a measurement.
    That a common core thing?
  1. add oil to manual transmission
    By hondalx85 in forum 2geez Tech & Performance
    Last Post: 08-20-2010, 04:30 PM
  2. Need a Manual Transmission
    By mephi in forum Wanted
    Last Post: 02-23-2009, 10:34 PM
  3. Manual Transmission Oil
    By x3r0 in forum 3geez Accords
    Last Post: 11-04-2008, 09:44 PM
  4. manual transmission
    By beck432 in forum 3geez Accords
    Last Post: 11-15-2004, 08:28 AM
  5. 87 Civic transmission swap thoughts
    Last Post: 11-02-2004, 08:14 AM
