Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: EGR delete
    10/Honda/Ridgeline
    NJ
    Re: EGR delete
    Removal of the EGR system does not increase your HP, you know it, but you want to remove it anyway cause it un-clutters the engine bay and thats just aesthetics.
    Now, remind me, why is this posted under performance?
    I would say just wait till you convert to OBD-1 like you mentioned and then worry about removing the EGR.
    Re: EGR delete
    Quote Originally Posted by smufguy View Post
    even when i had obd1 i had my egr valve...not untill i got my b16 mani that i closed it off
    Re: EGR delete
    why would anyone on here want to run with the cel on? its making your car run in limp mode and extremely rich..., yeah it looks better without it but is shitty mpg, engine full of carbon, clogged cat ,and less hp really worth making the engine look better?
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Re: EGR delete
    I dunno, I've tracked my car's fuel consumption since the day I got it and removing the EGR made literally no difference. Takes no longer to warm up, gets the same 30-33 mpg that it did with the EGR working. I agree it's retarded to yank it out and let the car think it's "broken," but it doesn't appear to be affecting anything.
    Nov 2000
    Re: EGR delete
    In fact, removing the EGR valve may end up causing a requirement to run higher octane fuel. On cars like ours without a knock sensor the EGR actually reduces knocking. I don't want to be obnoxious, but I don't so much care for removal of emission controls. We're not driving race cars. I have to pass a tailpipe sniffer test every year so I don't have a choice other than keeping everything functional and it hasn't been that hard to do. I won't give you any tree-hugger lectures because I am not one, but I like the concept of keeping it all working. Honda is not the type of manufacturer to add devices to the engine bay without good reason.
    Joay's Avatar
    Sep 2008
    Re: EGR delete
    That all makes sense, but it does still work. And the reason Honda put an EGR on in the first place isn't because it's critical to the proper functioning of the engine, it's there to placate consumer concerns at the time (EGR wasn't required in the States until the mid-nineties if I'm not mistaken). Furthermore, many JDM motors of the same time period don't have EGR valves.
    I get where you're coming from. My dad makes the same argument for everything I do to my car, citing the "If it ain't broke" addage, but he (and you) and I have differing definitions of "broke."
    Nov 2000
    Re: EGR delete
    That is completely fair. I like it. My car is still sometimes like a big toy to me so I do understand messing with it. I seem to recall cars of much older vintage having EGR valves. I started learning auto mechanics by experience in 1979 so, yeah, I'm a bit older than a lot of this forum. I still remember those stupid ass belt driven air injection pumps they put on cars in the late 70's and early 80's. My Accord is actually just as fast as my 72 Pontiac Catalina with its 6.6 liter engine. Even some of the cheapest cars are faster than ours these days. I am just a big fan of efficient power without excess. Having a truly fast car would just be frustrating to me as I sit in Dallas area traffic and Lewisville traffic lights.
    If your dad and I sound similar it could be because he's close to the same age as me - I'll bet. I'm too old to be Gen X and too young to be a baby boomer. I wonder what that makes me.
  8. #33
    LX User resendez's Avatar
    Nov 2009
    88 accord lx-i
    peoria, AZ
    Re: EGR delete
    i do not have my egr plugged in dont plan on plugging it in either is there a problem with doing this or wat. im not sure wat it does but my car dont idle funny no more 1500-2000 rpm up and down doesnt stop untill i stopped using it
  9. #34
    cygnus x-1's Avatar
    Chicago area
    Re: EGR delete
    Quote Originally Posted by DBMaster View Post
    EGR valves go back to the '70s. First car was a '78 Malibu with the Chevy 305. It was one of the last with an all mechanical fuel system and emission controls. No smog pump but it did have an EGR valve and charcoal can. It looked like shit (literally, it was a medium brown color) but always ran and had a fair amount of pick up. Couldn't turn corners to save it's life but most domestics couldn't back then. That's the one thing you will find with these little Hondas. They aren't fast, but they are very nimble and fun to drive.
    C|
  10. #35
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    Re: EGR delete
    My '86 constantly has the EGR code flashing under the seat, and I average about 28-29 MPG. My head gasket is bad and I may have a cracked head, so I'm swapping my head for an '89 A20A3 head and doing my head gasket at the same time. While I'm in there, messing with the EGR will be easy, and I've been debating on deleting it or not.
    When I first got the code I tested what I could. A lab scope test showed the sensor knew what position the valve was in, but I think it had a leak and pressure would drop in a couple seconds. This led me to believe the EGR solenoid is bad, so I just left it disconnected. The parts car I got the head from has a known good EGR solenoid but it looks different, I was thinking of using it to just see what would happen. From the start I only wanted to get rid of the entire system, but reading this it sounds like some of you would think it'd be worth the time to see if that could fix my issue. What do our cars lose from having no EGR?
  11. #36
    Re: EGR delete
    Quote Originally Posted by Fixedit View Post
    EGR helps with ping on some cars but on ours it does little. The heads pretty efficient. Might need it to pass emissions with Nox. it cools the combustion charge. Im sure you can read up on it thru google.
    I havn't run it in years and I get the 28-30 mpg your talking about. I get about 23 mpg with E-85.
  12. #37
    Feb 2015
    Oregon
    Re: EGR delete
    Okay, I feel like from what I've gathered I'll be fine without it. I know down the road I'll delete it, whether or not I do it with the head swap is a matter of how much time I have. Thank you for the info!
  13. #38
    Feb 2015
    Oregon
    Re: EGR delete
    Ended up doing it the other night with my head swap. Got rid of my EGR code (for now, watch as I go check today and have it giving me 12 flashes again now that I've said something). Feel pretty good about it
  1. Delete or not to delete the EGR sys.
    By firefighterwhite89 in forum Restoration & Custom Fabrication
    Last Post: 02-16-2011, 01:33 PM
  2. p/s delete?
    By 89accordvtec? in forum 3geez Accords
    Last Post: 11-24-2010, 08:23 PM
  3. a/c delete?
    By 88lxi-shortram in forum 3geez Accords
    Last Post: 11-19-2010, 08:31 PM
  4. Delete
    By Cyric_accord in forum Trading Post
    Last Post: 04-12-2004, 09:29 PM
  5. please delete
    By carlessNcareless in forum Classic Honda Pics & Videos
    Last Post: 12-05-2002, 06:36 AM
