Results 1 to 12 of 12
Thread: Idle problems
    Dec 2009
    89 lx-I sedan :)... auto :(
    Idle problems
    So, sometimes my car will just be sittin there and the idle goes up to about 2k and drops to about 1.4k and just goes back and fourth rapidly almost like its trying to revv itself i have no clue what the problem is.
    any ideas??
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Re: Idle problems
    I'm currently having the same problem, I'm going to adjust my Idle screw again and if that fixs it i'll let you know.
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Re: Idle problems
    Okay I fixed my issue, So here is how you do it.
    1. Start your car.
    2. Listen to your idle for a little while.
    3. You will need to disconnect the power from the IAC, *it will be a cable right behind your intake, it actually hooks in to the intake manifold*
    4. After doing so, Adjust the Idle screw, *it will be a flat head screw right above your throttle body I believe.*
    5. Adjust it till your idle is about 50+ above what you want.
    6. Plug the cable back in, and let the car run for like 2-5 minutes.
    7. Turn off car and restart. Should be fine.
    Hope this helps you out a bit, If you need more I'll try and get pictures later.
    Re: Idle problems
    u can also fix this by cleaning the IACV
    Dec 2009
    Re: Idle problems
    what is the iacv
    Re: Idle problems
    You will need a priest and a lot of holy water to fix this problem.
    ...Or you could just search...
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Re: Idle problems
    http://www.honda-tech.com/showthread.php?t=1575913
    go there.
    wildoutwhitegsr has a pretty good right up for you.
    Re: Idle problems
    Quote Originally Posted by stevo89 View Post
    what is the iacv
    Idle Air Control Valve. Mine tore open and caused my car to have the same problem (and overheat, too), except since my car idles really low, my car jumped from 600rpm-1700rpm.
    Re: Idle problems
    http://www.youtube.com/watch?v=-cA2PFPPt0Q < this is ur problem right
    Dec 2009
    Re: Idle problems
    Yes exactly
    Re: Idle problems
    Same problem as my car. Does it overheat after a few minutes?
    Re: Idle problems
    mine never overheated even when i blew the head gasket lol
    i just adjusted the idle down on my 3g .. on my civic i cleaned the iacv and that fixed it same with my 4th gen but then my 4th gens started acting up again lol so i adjusted the idle down so i no longer have a cold idle lol always just at 900ish
  1. New Car IDle Problems
    By SharkyX in forum Carburetor Tech
    Last Post: 01-27-2009, 02:41 PM
  2. Idle problems
    By locknload68 in forum Carburetor Tech
    Last Post: 11-27-2003, 08:46 AM
  3. Idle problems
    By pinang in forum 3geez Accords
    Last Post: 06-12-2003, 11:35 PM
  4. having problems with idle
    By 86dxautohatchback in forum Carburetor Tech
    Last Post: 11-03-2002, 02:54 AM
  5. Idle Problems
    By Coitis1 in forum 3geez Accords
    Last Post: 07-07-2002, 12:13 PM
