Results 1 to 11 of 11
Thread: My stupid suspension
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Angry My stupid suspension
    I still can't believe a fairly easy job changing struts and springs can bring up shot load of troubles.
    For those who's car has gone through snow, sleet, mud, rain what have you, expect frozen bolts and more suprises.
    Okie, I got around the frozen bolts and a pack of ciggarettes, but the STUPID LOCKING NUT is jammed TIGHT on the struts. WTFFFF
    This car is possesed I tell you.
    PS: ANYBODY HAS THE SUSPENSION PARTS (BOOT, BUMP STOPS, SEAT, BASE, ETC...) PLEASE PM ME!!
    86 Honda Accord LXI HB 5-sp
    Central California
    air ratchet won't take those off?
    Otherwise I know they are in a sucky location to be able to really put some back bone into them.
    Now I d
    SEi User jigga225's Avatar
    Louisiana
    loosen the bolt on top of the strut, the one that is under the hood.
    Then you may be able to turn the fork a little to where you can get a cheater on the nut.... use kroil or wd 40
    peace
    Jun 2001
    88 lxi coupe
    gainesville, fl
    i think you guys got it wrong.
    It's the nut on top of the struts that are jammed tight. The one that you need to use an allen wrench.
    Broke an allen key, destroyed an allen socket, half a can of pb blaster, still not moving
    So any one who has all the boot, bump stops, collar, seat etc...sell it to me please.
    YK86's Avatar
    Oct 2000
    BC, Canada
    If those struts are going in the garbage, use spring compressors (very important) and compress the spring. Use a drill and drill in the middle of the allen hole and use a bigger and bigger bit til the nut falls off. That's what I had to do to take apart a Taurus strut I changed for a co-worker before. If you are going to use it again, I think an impact gun or heating and using a air wrench will be the only way.
    www.b20accord.com
    Jun 2001
    88 lxi coupe
    gainesville, fl
    yeap also tried with an air wrench, it still won't budge.
    I have put the suspension back on with prelude arms..hihi...my wheels are like this \ / and difficult as hell to corner
    ps: is there a rear jacking point to bring both rear wheels up? I don't have a hook on mine.
    YK86's Avatar
    Oct 2000
    BC, Canada
    There's a bump in the middle if you look underneath (trunk floor). You can jack it up there. And it seems like you are going to have to drill that nut off the strut.
    www.b20accord.com
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    i had a lot of trouble with mine, i ended up having to set it on a brick, and stand on the strut, then pull with the ultimate cheater attached to the allen wrench! it was a 5 foot metal tube! that fuck broke loose right away. but also try lots of wd40 or liquid wrench, i thought mine would never come off, but it was no sweat with proper leverage!
    btw, if youre breaking allen wrenches you need better allen wrenches... mine bent like hell, but never snapped!
    cut the shit off and get new struts.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    I'm sneak some from the junkers. hopefully those doesn't have the same trouble
    PS: The spindle nut is 32mm??
    accord HB ( metallic green)
    B.C Chilliwack
    32mm is right
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
  1. A stupid is as a stupid does
    By phrenology in forum Classic Honda Community Chat
    Last Post: 09-26-2010, 07:47 AM
  2. I'm so stupid.
    By hewofmatt in forum 3geez Accords
    Last Post: 09-23-2008, 07:38 PM
  3. Stupid car!
    By 88accordalltheway in forum Classic Honda Pics & Videos
    Last Post: 10-26-2005, 02:38 PM
  4. I'm stupid need help
    By #4bandit in forum General Engine Swaps
    Last Post: 08-29-2004, 09:44 AM
  5. stupid EQ!!
    By pimp86LX in forum Interior & Exterior Care
    Last Post: 08-16-2002, 09:25 PM
