Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Thread: Rotor Question
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Rotor Question
    how to change a four lug to a five lug? what would i need to do and what i need? or has anyone tried this if so you got pics of the car with 5 lugs i would be happy to see it. wanna know cause their is more options of rims to choose from with 5 lugs thanks in advance
    Re: Rotor Question
    ima let you choose one of my many answers
    "what do "you" think you need?"
    what rims our out there that are 5 lug that you cant find a compairable set in 4x100
    search?
    you would need the same thing as any other car would need for a 5 lug swap
    good luck finding hubs that will work
    fuckin noobs
    Oct 2009
    Re: Rotor Question
    ok lol and whats your deal man not getting laid or what lol
    Re: Rotor Question
    just sick of seeing stupid questions is all... if you HONESTLY have no clue on how to do one then you really shouldnt be atempting it, you have to miss match hubs from other cars wich can throw your suspention way outa wack, if you couldnt take the time to atleast look up 5 lug swaps "in general" then what makes you think anyone wants to look up all the answers for you
    if you came in asking things like ok i have reasrched this this and this hub wich one do you think is the best way then you might get a better answer. lazzyness shouldnt be rewarded
    Re: Rotor Question
    facepalm... you cant 5 lug a 3g... and even if you "can" no one knows about it how has ever done it has long as ive been a member....
    also.. 4x100 is the most common rim size... think about it man... what do civics have? 4x100... what is the most populer tuned car? civic...
    Oct 2009
    Re: Rotor Question
    hmm but i could of sworn i saw a 3g with 5 lug
    Oct 2009
    Re: Rotor Question
    lol alright then
    Re: Rotor Question
    It could probably be done, but no one has bothered yet, I had to pass up some beautiful five lug rims with nearly new tires for a hundred bucks, due to them being 5 lug. what you need to know is the specs on the wheel bearings on the four and five lug. if the wheel bearings are the same, you can change the front hubs easy. the hubs need to be pressed off of the bearings though. and you would need a brake rotor to match the hubs, if you have rear drums i'm sure it can be done, a lot of honda's that have rear drums have similar setups. the main question is why all the trouble? I know there is a lot more honda stuff that will probably swap on these cars, but no one has really figured it all out yet, If i had the money and space, i would be experimenting with parts swapping every day on test three gees.
    Oct 2009
    Re: Rotor Question
    i only ask cause i thought i saw a 3g with five lugs on this site or i could of been wrong and could of been a 4th gen accord
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: Rotor Question
    Sure, it was a AWD subaru swap one member here was doing, was a long time cince hes posted, but yes.. He had a reason to go 5lug, but you? Whats your main reason?
    My Build Thread
    Jan 2009
    89 Accord LX-i coupe
    Illinois
    Re: Rotor Question
    If you have to ask, you can't do it. This question is too general. It would require lots of fabrication and time spent finding stuff that fits, and you'd end up with some kind of frankenstein that you can't find parts for. just don't do it, there's more than enough wheel choices in 4X100.
    If you want to have 5 lug, trade your Accord for a car that has 5 lugs.
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: Rotor Question
    that is an good idea!! trade it for 5 gen Accord.
    My Build Thread
    Re: Rotor Question
    Tommy from thailand has done it check his thread out. i think hes got 4th gen stuff on it.
    Re: Rotor Question
    4th gens are still 4 lug just 4X114 first your to have 5 lug accords were 98 and that was on the V6's
    Oct 2009
    Re: Rotor Question
    Ok thanks for the info guy and sorry I posted this thread how do I close the thread I tried looking for the close thread and couldn't find it and if you want you guys can flame me or call me a noob I don't give a shit no offense they are just words so it don't bother me lol
    Re: Rotor Question
    yep your right i was thinking it was a 5 bolt set up. Acura Integra Type R is 5 bolt might look into those pieces. The front arms might be close but the rear is the low compact design.
    LX User accordion89's Avatar
    1989 ACCORD LX
    Seattle
    Re: Rotor Question
    I want a 5-lug conversion because they dont make alot of 4x100 spreewell spinners, three6mafia: "I'm riding spinnas i'm riding spinnaz, they dont stop..." lol
    Re: Rotor Question
    I don't think you need to close it,it just needs to be cleaned up, you did post a legitimate question, it's just not really needed for this car.
    Re: Rotor Question
    if the wheels bearings fit the spindles, you wouldn't have to change anything but hubs, on the rear has anyone seen if the bearings from the accord fit the SEI spindles?
    Jan 2010
    Re: Rotor Question
    If you really want to do it... you'd probably want to start by mimicking what da9 integra/ ef civic guys do.For the fronts, the Width of the Type R bearing (1.6142") is identical to the width of the Accord bearing. So thats a plus. The inner bore is 1.5748" for the Accord and Integra R is 1.6929. Get a 5 lug hub from an integra type r and try out the following.
    Take your Accord hub and bearing to the local machine shop. Get both mic'd so that you know the clearance between the hub and the bearing. Then have the teg hub shaved to fit your accord bearing. Press on the new hub and check the runout.
    The rear....God, you are on your own.
    Lastly, 5 lug means new brakes, wheels, etc...Basically headaches. 4lug Hondas are so popular that you really don't need 5lugs to benefit from better wheels, or brakes or whatever.
    Re: Rotor Question
    http://www.hybridautomotive.com/tech/5lug/
    heres some pictures on this link. Good info above as well.
    Have you looked into wheel spacers ?
    SE-i Sedan 5 spd
    Re: Rotor Question
    ...fuckin noobs
    I really don't think a response like this helps the board. The original question, which is a legitimate one, has come up from time to time, most recently a few months ago on this thread:
    https://www.3geez.com/forum/showthrea...ght=wheel+lugs
    Someone that is new to the car might well want to know about this. If they used Search, and put in "5 lug" or "five lug" as I did, nothing would be returned. I gather the search function doesn't respond to numbers, as posts in the referenced thread have "5 lug" in several places. I did find the thread by searching for "wheel lugs," but that isn't as obvious as "5 lug."
    I think we should turn down the heat some, or at least save it until it's needed.
    Jan 2010
    Re: Rotor Question
    +1, to that. If I could get my hands on a spare knuckle, I would definitely do this.
    Re: Rotor Question
    that also wasnt the only thing i have posted in this thread, not to mention back when you were learning cars did you come in and ask, how doe sa motor work or anytihng like that? doubt it you looked up how the system works in general, just like he coulda done, if he came in asking about certain hubs or spindals id be happy to help but i really dont think spoonfeeding answers is the right thing to do
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: Rotor Question
    Umm I think there nothing to discus here..
    Here is what he prolly seen https://www.3geez.com/forum/showthrea...595#post873595
    My Build Thread
  1. AEM rotor question
    By Magny in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-27-2004, 09:02 PM
  2. New Cap And Rotor!
    Last Post: 11-01-2003, 05:35 PM
  3. cap and rotor?
    By jagojon3 in forum 3geez Accords
    Last Post: 05-02-2003, 11:33 AM
  4. CV and ROTOR
    Last Post: 04-10-2003, 06:45 AM
  5. Cap And Rotor
    By My 89 Accord Lxi in forum Performance
    Last Post: 10-09-2002, 10:28 AM
