Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: You're all aware of my piece of crap LX-i...
    ...and how it's continuously having problems. Or is that just Mike and the people on my Facebook? Anyways, yesterday morning, I got in my car, it started right up, and I drove it to school for a swim meet. A few minutes later, I tried starting my car (away meet) and it wouldn't start. It was acting like I wasn't pushing in the clutch, when I was. It wouldn't do anything at all. The regular "check" lights would come on when I turned the key to the second position (first being the stereo one), but when I turned the key to the "start / III" position, nothing happened. Knowing the cure before, I let the car sit (about 10 hours this time, long meet), but when I went back to it the damn thing still wouldn't start. I had to push it and pop the clutch to get it home. It's been having a lot of starting / idling problems lately, maybe because it's cold? Sometimes it starts right up, sometimes it cranks forever, sometimes it cranks slowly a few times, sometimes it doesn't start at all. Possibly problems/suggestions? Yes, I have gas in it this time, thank you (long story).
    Jan 2009
    89 Accord LX-i coupe
    Illinois
    Re: You're all aware of my piece of crap LX-i...
    With your mix and match of no-crank, slow-crank, and no-starts, I would start by checking all the ground circuits.
    probably the ignition switch, Nappa has it, the last time i got one, it said Echlin on the box, but the switch was in plastic stamped Honda. they go bad and the start position burns out over time. it's easy to fix, take off the plastic surrounding the column, and there will be two screws holding it to the back of the mechanical part of the switch. take these off and unplug the wiring connector. test it under the hood first, jumper the small wire plugged into the starter , the solenoid wire, to the positive side of the battery, and see if it cranks. make sure it's in neutral!! if it cranks now, it's probably the switch, this is a very common problem.
    I just went out to it again. It hasn't been driven since 5pm last night (PST) and it still won't start. It's still acting like the clutch isn't in: that's the best way I can describe it.
    did you read my post?
    Yes, and thanks for the help. But, it's whatever. I'm not coming back to this site anytime soon.
    Jan 2009
    Illinois
    I understand Charlie. The reason I say grounds and connections is because of the slow cranking.
    well if he doesn't want my help, oh well.
    nobody cares, lol
    hell dude Ive been here a while and my posts go ignored all the time so dont act like that
    try by passing your clutch safety switch under the pedal first, then clean the battery terminals with a proper terminal cleaning tool, then check your starter wires n connections
    nobody cares, lol
    needs to verify voltage at the starter solenoid terminal while cranking. I don't think he will be back he deleted all his contact info.
    i had this problem... it was the wire that went to the starter needed to have a new spade crimp put on it ( really the whole wire needed to be replaced but the new crimp worked)
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Thumbs down Re: You're all aware of my piece of crap LX-i...
    what went up his A hole?? and dont worry lost its cool i bet hes doing it anyways if he wants his car running normal again. but he shouldnt take it out on the thread he posted
    Lost, it's not you, it has nothing to do with you, so don't worry. I did want/need your help, I'm taking care of the problem, and I thank you.
    https://www.3geez.com/forum/showthread.php?t=71499
    don't quit because of some noobs.
    Mar 2008
    88 Accord Lx 5 Speed Sedan
    Seattle Washington
    Yay hes gone! Such a smart ass i never wanted to talk shit cuz i dont wanna get banned but wooo i love this post lmao
    Oct 2009
    Quote Originally Posted by Juggalo88Accord View Post
    lol man you are one funny guy hahah
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    If you do come back Charlie a possible thing to check is the clutch interlock switch. This switch is mounted above the pivot point of the clutch pedal arm. When you depress the clutch this switch provides a path to ground that is necessary to energize the starter relay coil which in turn provides the necessary power to the starter solenoid which when energized provides power to the starter motor. This is one of many possibilities to explain if the engine is not cranking over. As DWM said "I would start by checking all the ground circuits." This is one of those ground circuits.
    Charlie I saw the thread, and yes they were mean to you.BFD You are pretty obnoxious and bold in your comments in other threads but in case you did'nt notice it was tolerated because you were well inside the rules. So hold your chin up and take it what you dish out just a bit.
    Obviousley you have some respect here or you would not have anyone posting assistence to your question.
    Jan 2009
    Illinois
    You should stick around Charlie, you're alright with me. These chuckleheads who keep starting new threads with easy questions that have already been answered are who need to leave.
    like I said , eliminate the clutch safety switch being a problem first, bypass it with a jumper
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Charlie, Dont get angry at n00bs pliz man!! Just ignore it. You know you only show your sides with shit like that, and I can tell you this, as an old saying goes. Dont touch the shit it will stink. Just calm down and we will figure out your starting problem, Im sure its bad connection somewhere. 75% of all problems with a car is electrical.
    My Build Thread
    let me know whats going on with it and i'll walk you through it. have you checked the simple stuff? check to make sure your battery positive and negative are tight, if they are loose everything will come on, but there won't be enough current to crank the engine. pull the terminals off, clean with a mix of baking soda and water, tighten them back up. pull the grounds off where they attach to the body, and sand the metal under the terminal and the terminal.
    LX User jg09's Avatar
    Nov 2009
    1992 Ford Explorer XLT 4x4
    Everson
    hmmm, well charlie deleted me off facebook, too, so idk what's up
    Quote Originally Posted by accordion89 View Post
    fkuc yuo! 9'M G0ING To nework tommorow! at lest i goti a job like a corn on a [email protected]! bitch!
    wtf...
    This post is fucking amazing...you deserve an award for this. Im not sure what you are trying to say...but it is amazing
    Quote Originally Posted by jg09 View Post
    Same here haha sick of having over 9000 friends i guess
  1. 86ccords update thread!! 56k's be AWARE!!
    Last Post: 03-17-2012, 05:34 PM
  2. piece o' f'ing crap trivia!!!!
    By Ravenix in forum 3geez Accords
    Last Post: 04-05-2004, 03:44 PM
  3. piece o' f'ing crap trivia!!!!
    By Ravenix in forum Performance
    Last Post: 04-03-2004, 02:04 PM
  4. Trim piece
    By LXIHATCHRIDE in forum Trading Post
    Last Post: 09-16-2003, 05:50 AM
  5. Piece of Sh*t
    By Chris86Lxi in forum Performance
    Last Post: 07-25-2002, 05:41 PM
