w261w261
Maybe it's a fuel problem of some kind. If it sounds like an "almost backfire," a backfire in the intake is caused by an overly-lean mixture. If you were starving for fuel, when it first caught you might get that kind of noise. If it were the old days of carbs and fuel pumps in the engine compartment pulling fuel under negative pressure from the tank, I'd think you could be getting some vapor lock. This isn't so common with high-pressure fuel systems with the pump in the tank. Still, maybe you have a weak pump or a small pressure leak, and after the car sits hot you get vapor in the fuel line instead of liquid. After cranking for awhile, the pump fully pressurizes, but there's still some "bubbles" left, which might need to be digested before the car runs well. Hence, the sort-of-backfire.
If there's a way to measure the fuel pressure after it's been sitting while hot, that's where I'd start.
