Results 1 to 14 of 14
Thread: 89 dies and wont start
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Ok guys i've been looking for 3 days now and cant figure this out.
    Driving home from work the car dies and wont start again. I get it towed to my house and change the dizzy,main relay,coil. Nothing different. Turns over great but wont start.
    Next day after work i try to start it when i get home thinking "why not try"
    It starts and runs.....for 10 seconds then dies. Wont start again.
    I change the fuel pump and filter. Try a different ignition switch,change the injector resistor. It sprays gas the the fuel line and gets consistent regular spark
    I may have forgotten a couple things i checked but any ideas?
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Re: 89 dies and wont start
    If you have good spark a fuel try spraying gas into the intake an try to start it if that works your injectors arent spraying. if it still dosent start then do a compression test to make sure you have atleast 110psi or better if its higher make sure all the cylinders are close to the same an if that checks out then check your timming belt it could have jumped a tooth or two.
    Apr 2007
    NW Arkansas
    K theres two lol
    I spray if with starter fluid it'll run
    timing marks are dead on still
    How do i check to make sure the injectors are working if it doesnt run?
    Or what runs the injectors that i have'nt tried?
    Jan 2010
    First check your fuel pressue to make sure you have around 42psi or better and if you do then unplug youe connectors in your wire harness an check for bad connections if they are all good look under ur front drivers seat or behind the kick panel on the passenger an find the dianostic lite on your ecu an get you a repair manual an it will tell you how to go about retrieving the codes an even tell you if your ecu is bad if you read it right.
    eyah definately check the LED in the ecu under ur seat. another thing you can try is plug in a spare dizzy and turn it over by hand with the ignition on. you should hear the injectors clicking and the fuel pump should come on
    Apr 2007
    NW Arkansas
    No Cel and i've changed the dizzy already.
    Gonna look into the Tw sensor and injectors now. Finally not raining here
    Apr 2007
    NW Arkansas
    Got it ty
    Short in yellow/black wire from main relay to injector resistor. Only took 4 days to find lol
    Jeez, I'm impressed. Nice work sir!
    Jan 2010
    you are very welcome sir!
    Apr 2007
    NW Arkansas
    that manual is a life saver for finding shorts omg
    i wish i would have checked the fuel at the cylinders. I would have probably saved alot of time and work
    Jan 2010
    I no a good bit about cars in general but i have learned to purchase a repair manual for times like yours and now i always get a manual for every thing i own becaues i have had my share of guessing trial an error an spending alot of money i didnt have to on the simple things. Im so glad that you found it though!
    Apr 2007
    NW Arkansas
    check this out man. good stuff
    from technical section here
    downloadable service manual
    https://www.3geez.com/forum/showthread.php?t=25137
    Apr 2007
    NW Arkansas
    I never thanked you properly THANK YOU! ou got me in the right direction here
    Apr 2007
    NW Arkansas
    Quote Originally Posted by stephensimmons View Post
    if you have good spark a fuel try spraying gas into the intake an try to start it if that works your injectors arent spraying. If it still dosent start then do a compression test to make sure you have atleast 110psi or better if its higher make sure all the cylinders are close to the same an if that checks out then check your timming belt it could have jumped a tooth or two.
    tyvm
  1. 1989 accord dies and now wont start
    By enigma2446 in forum 3geez Accords
    Last Post: 08-20-2012, 03:19 PM
  2. 1989 accord dies and now wont start
    Last Post: 08-18-2012, 03:29 PM
  3. Car dies and wont start...
    By Bullit in forum 3geez Accords
    Last Post: 05-21-2007, 06:40 PM
  4. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  5. Car dies right after I start it....?!
    By 88WhiteLX-i in forum 3geez Accords
    Last Post: 02-21-2003, 06:02 AM
