Results 1 to 20 of 20
Thread: right brake lights wont work
    DX User 9shorty20's Avatar
    Sep 2008
    Perris Ca
    the right brake lights on my car only come on sometimes...its just the brake lights cuz when i turn the headlights on all of the back ones turn on.this is driving me crazy i dont know what it is.i checked the bulbs fuses and everything is good..can someone help me...thanks
    DOUBLE S ARMY
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: right brake lights wont work
    You might have a short some bouncing around check the wires and grounds too
    Check the adjustment of your brake light switch at the pedal. Also check the condition of your bulb sockets.
    Quote Originally Posted by 9shorty20 View Post
    pull the bulbs and check for corrosion at the bulb and socket, the other lamps come on because they are a different filament, clean up the sockets if they are corroded and get a little tube of electronic contact grease, put some on the bulb and in the socket before you put the bulb back in. This ensures the corrosion won't return and will maintain the contact.
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Check around the sockets on the bulbs as well, see if anything is melted or looks moist.
    My AE92 kept melting brake lights holders and wire connections. because the bulbs kept getting to hot.
    There are a lot of things that can go wrong with brake lights.
    Quote Originally Posted by Nio View Post
    if the sockets are melted you can get ones off any honda at the yard, as far as i know 90 percent of them are interchangeable.
    also check the black box mounted on the light is plugged in properly
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Yea, If it turns out to be something like this, just head to a junk yard. I plan to soon just so I can pick up a replacement for my right brake light cause the plastic holders have broke.
    Sep 2008
    Perris Ca
    turns out it was just some loose wires on the wire harness that connects to the bulbs..anyone know where i cant get another one..besides the yard
    DOUBLE S ARMY
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    OK I looked up NAPA and it did not show, but that does not mean they can't get them. Now I am not an Autozone person at all, but I did find brake light sockets on there site if that is what you need. Since it is only a socket and you do not want to go to a junkyard, then since it is only a socket ( If that is what you need ), then they do list them.
    : I do not condone this behavior !!!!! I am not an Autozone person at all. But it is only a simple socket. I still say go to the boneyard. But if you need the other harness plug end then ignore me. But always NAPA!!!!!!!!!!!!
    http://www.autozone.com/autozone/cat...uestid=1076782
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    Quote Originally Posted by Bluntman View Post
    can someone just send him a couple? i'm sure someone has some extra sockets around. I checked and I don't have any.
    Sep 2008
    Perris Ca
    its the whole wire harness that i need...i checked kragen auto zone etc...and they dont have them im guessing i have to order them.does anyone know of an online store where i can get em??
    DOUBLE S ARMY
    what do you mean by the entire harness? from where to where?
    Apr 2009
    Orange County Cal.
    Is this what you need? And only one? There has to be junkyards in Perris. But I am in Orange County, so maybe I can figure something out for you.
    whats wrong in the harness? is it the bulb socket? replace the socket if it's bad
    Sep 2008
    Perris Ca
    yea bluntman thats the one i need..but mine has three sockets...i wanted to find out if there was any stores that sold them..instead of going to the yard and getting a used one...ima probably end up going though.once the rain stops of course
    DOUBLE S ARMY
    right side? sedan right? i grabbed one for you
    pm me your addy and i'll send it to you
    Jan 2010
    1988 accord lxi auto
    madera ca
    I have the same problem, was it the wiring harness you guys circled and where do I get one. also the black box on the back of the assembly, how do I test that, and then where do I get one if it is bad?
    Sep 2008
    Perris Ca
    it was a loose wire in the wire harness..if i moved it or taped it it would work but as soon as i hit a bumb it moved and would mess up again..try moving the cables around to see if its that
    DOUBLE S ARMY
  1. Brake lights wont turn off!
    By 86ACRDLX in forum Classic Honda Community Chat
    Last Post: 08-11-2024, 12:09 AM
  2. My brake lights wont turn off!!!???!!!
    By King Peetis in forum 3geez Accords
    Last Post: 10-04-2009, 12:35 PM
  3. Brake lights sometime work?!
    By mrmunka in forum 3geez Accords
    Last Post: 03-04-2008, 05:52 PM
  4. Tail lights wont work
    By MR_ACCORD_SI in forum Interior & Exterior Care
    Last Post: 10-22-2003, 06:13 AM
  5. My brake lights wont work for the life of me.
    By pimp86LX in forum 3geez Accords
    Last Post: 08-13-2003, 01:27 PM
