lostforawhile
all he did was disconnect the O2 sensor, they are very much connected to the carb, the system has no way of detecting this is a fault though, the big white valves on the side of the engine allow air into the manifold in pulses, this leans the mixture to a normal mixture, it gets the rich lean data through the o2 sensor and some other parameters, th problem is the electronic and mechanical control systems don't communicate with each other, it has a computer in the sense it detects inputs and changes the output based on them, but it's a very primitive computer, It could be the dual carb keihin now with it's check engine lights and tps sensors and everything else. Be glad it's not.
