got it running yep
NZ new CRX AC radiator delete pipe installed
Carpet installed
in with the dash
Hooked up the digital dash and the ECU VSS connected to the back of the dash. only two error codes, 41 and 20, ELD can go to hell and the o2 heater can also gtfo
engine seems to take a lot of cranking to start up. and when it does start if you floor it it will misfire and stumble. Im blaming the dizzy cap/rotor as it has new plugs and leads.
