the harness looks something like this
http://cgi.ebay.com/ebaymotors/HARNE...Q5fAccessories
So with the normal 60 watts will I need a harness for the luminics and autopals?
would that harness work on the 3g labelskater? just curious since i order bulbs for 85 watts to 100..
and if you want the prjectors ill sell them to you lol
yup...best bet is hella or auto pals with hids or silverstars if you want a stock bright headlight
That harness should work on 3g and you can pretty much see the difference with headlight brightness even with stock sealed beams.
Nobody Mentions the BOSCH housings.
I got those on the Sedan and they're just awesome
I need these parts!
So that's the right one? You have one by chance?
I don't want to buy that one if you have the same kind, how much for yours?
I'm buying the autopals as we speak.. I'd like to run 90/100w bulbs tho so I need the harness
ALSO..
This one -
http://cgi.ebay.com/ebaymotors/200mm...item35982c01f8
or this one -
http://cgi.ebay.com/ebaymotors/200mm...item4ce8f6e2f3
Not to be a pest, but I need confirmation on the correct housing and whether or not to buy that harness.
Im anxious to get them
yes that is the correct harness you need to run that setup,
also i saw someone asking if you need the harness to run luminics. wich it will depend wich ones you get as they have H4s in stock volatages and in the higher volatages. so be carefull when buying if you dont want to run the upgrade harness.
heres the lower volatage setup on my girls civic, the cam filterd out alot of the blueish color and its raining lol
with flash on
cam flash off
those are the 7,050K bulbs at the stock 55/60 wattage.
i have the 100/90 bulbs aswell wich would need the harness only reason we didnt run them in the civic was due to the civics headlights are plastic and the added heat would melt the hell outa them. but that would be no problem for the glass caseings for the 3gee
Great thanks, and the housing? Do I need the DOT approved ones or other style?
They are both autopals 200mm euro style, just one is not DOT approved
Also I'm having trouble finding any bulbs on ebay higher than 55/60w, could someone help me out with the correct one? I really don't want to order a wrong part, since I'd have to ship it back instead of driving it to the store or something
Luminics Ultra white krypton 90/100w or w/e (I'm getting the harness)
90 watt low beams? Won't that be bright as fuck and just blind everybody? If you want more light why not get a set of running lights that can be turned off and put the high wattage bulbs in those? It's the same amount of work if you're rewiring, plus you have another set of lights instead of losing your 55/60s.
its actully not that bad and since they use normal cuttoffs it will be fine, now HIDs are a difrent story as witout a proper houseing they have no cuttoff
think of it as a house light turn on a 60 watt bulb then turn on a desk lamp its brighter but not alot same idea mostly LOL
This is how mine look. Not the best in the world, but plenty bright and do not blind people in front of me. Hella Ecodes with 35w 4500k hid setup.
~~NGK~~Silvania~~MSD~~Pioneer~~MSW~~Bosch~~DC Sports~~115WHP 116WTQ
ill be getting some hella bulbs soon but i wont be using then since i have 8500k bulbs
Just say no to higher k lol.
i know but this one is a bright blue not that lazy blue
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_5108wt_939
its from 55 to 65 watts
