Results 1 to 12 of 12
Thread: 87 2 door accord should i use premium midgrade or unleaded to keep it away from shop
    Oct 2002
    87 2 door accord should i use premium midgrade or unleaded to keep it away from shop. i mean if i use premium will that be more healther for my car plz answer im about to get gas in an hr
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    use regular
    and put $5 in a cofee can every time you fill up. I think the manual says it's ok..I only use HT when I'm heading for the emission test rollers
    86 Honda Accord LXI HB 5-sp
    Central California
    Hmmm, I used mid grade in the winter and as it warmed up and I started to hear slight pinging on heavy throttle on tip in, I'd run premium. But as soon as it got cold again I was back to mid grade.
    Now I d
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I always run regular unleaded. It never pings and I'm cheap though. Usuually the only difference in the more expensive gas is it's less likely to preignite. Since our engines are not especially high compression, they don't need premium (unless you have al ot of carbon buildup in the cylinder that raises compression). So try regular and if it pings at high rpm try mid. If that still doesn't work consider moivng up to premium.
    Here's some more information if you're curious:
    http://www.caranddriver.com/xp/Caran...eywords=octane
    Mike
    LX User Toby's Avatar
    Read Signature
    Australia, Rockhampton
    I use 98 octane fuel, I get more KM per tank using it
    -Eike
    __________________
    Honda Is The Best
    I Bought My Accord On 25th March 2002
    I Wrote My Accord Off On 26th April 2003
    Soon I Will Be Driving Another Honda
    No, getting higher than required octane doesn't make your car last longer so get regular if your car runs fine on it.
    Eric
    Jun 2002
    89 Lx auto
    i run 85 and never have any ping'ing hot or cold.
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    i heard that it should at least be 87
    1986/Accord/LX
    Tucson, AZ
    85? Doesn't the manual say 87+ only? I have never seen 85 at a station before.
    My Car: 1986 LX Accord
    Mods: Clear bumper lenses
    Engine: Thinking of converting to EFI or Weber Carb
    James
    LXi User Jerren's Avatar
    Jul 2001
    1991 H23 powered Accord EX Wagon , Turbo 91 Honda CRX, and 96 Blazer LT
    St. Louis
    i use 93 oct just because i have enough money...
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    i use 89. I found it strange that my car get's better gas milage with mid grade than it did with premium.
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    87accordlx's Avatar
    Sep 2001
    1987 honda accord lx
    Ontario
    i use regular, no problems
    -Scott
    3geez member since Sept. 27, 2001
    "its a shame that our society as glorified the thug life. It just churns out fearless idiots with guns " - Pimp86LX
  1. Premium Unleaded
    By Toby in forum Performance
    Last Post: 09-12-2002, 08:53 PM
