Replaced the rack while the Accord was dismantled . Upon refilling the power steering fliuid one of the four fittings that screw into bottom of the rack now leaks(drip,drip). The only thing is that the leak is not were the threads are @ the rack but were the line and the fitting meet( ya know the fitting rotates on the line in order to tighten it and there is a flange inside that it is supposed to be tightened against).This line looks like a brake line . The thing is screwed very tight into the rack . I guess the fluid has to be drained and am wondering if I must get a new line or another remedy....
