jasonrebellion
okay sooo... last week i was drivin down the interstate and i had a hose bust. it was a pin prick hole in one of the hoses going to my heater. I'm not sure if it was the return or sending hose....it was the one that went in below the other at the firewall, plugged into the heater control. so im assuming the "sending" hose. anywho, i replace the hose, and fill it back up with coolant..but I didn't bleed it from the valve next to the tw sensor and what not. so this morning i'm going to work and about 2 miles from my house the gauge spikes up, and it's in the red. i noticed I had ZERO warm air coming from my heater. so i get to looking and realize its bubbling out from the radiator cap that I replaced back when i did my thermostat(Phil probly remembers talkin to me on the phone). so i go to my bravada and pop the cap off it (it's rated for 16 lbs, not 13lbs like ours) and off i go around town to buy another cap for the honda and no problems. well I swap the new cap on and drive to mcd's and drop my wife off at work and it starts to over heat again. so i Popped that vlave open and let some air bubbles out, close it up and swap the 16 lb cap back on it "seems" all is good. why would the pressure in my coolant go up from changing a heater hose? Sorry for the long post just wondering..... its got a recent water pump, thermostat and now cap andheater hose. 1987 lxi.
