Results 1 to 4 of 4
Thread: Timing Marks
    Feb 2010
    Timing Marks
    I am running through the search to make certain that i am doing my timing right, however I cannot get a clear picture.
    I warm the vehicle up, (fan kicks twice), disconnect and plug the two distributor hoses and where they attach. I read i really only need to do one. I shine the timing light and I see a big "+". Then when i connect the hoses i see the 24. Is that correct or should i see the 24 with the hoses disconnected and connected?
    It is not the TDC mark, as that is the very faint "t", correct?
    On a side note on cold start up in the air cleaner box, there is a little circular hole next to carb on the driver side, I believe it is a pcv valve or something. However it makes a "Farting" Sound. It is sucking in a lot of air. When the car is warmed up though, no noise from it, however i do not think it is sucking in any air.
    Aug 2007
    Honda Accord-cowl Inducted, 351 CI Police Interceptor Air Filter with high rise hood
    around Tampa Florida, Paradise
    Re: Timing Marks
    On my car the "+" is a "T" that stands for Top Dead Center.
    With both hoses plugged, I rotate the distributor so that "24" lines up with the pointer beside the flywheel. That stands for 24 degrees of advance.
    The sticker under my hood says the advance should be 24 degrees.
    I then plug in the vacuum hoses.-Bob
    Hope this helps....
    I can't answer the PVC question, my car has a slightly different configuration.....but if you can post a pic, I might be able to answer.
    Quote Originally Posted by HondaLX View Post
    ---- spring/suspension installation help -mobile alignments -street lowering with your own stock springs...........
    Have a great day! [email protected] 813-839-4281 (24 hrs)
    Feb 2010
    Re: Timing Marks
    so if i am unable to see 24 degrees with the hoses disconnected i have a bad vacuum? Because i lined everything up right. And i can see the 24 degree with the hoses connected, just not when the hoses are disconnected
    Aug 2007
    Re: Timing Marks
    I don't know that you have a bad vacuum. I put in one of those hokey looking
    4" dia vac gauges from the A-parts store....wired up a light for it....works as an on-board diagnostic....ares marked red/green for normal usage.
    Mounted near the temp controls....if mounted too high, cops think it's a tach and want to talk to you....in my hood....
    It's my understanding that distrib timing is set with vac lines plugged...
    at 24 degrees for carbed..... My distrib is Hitachi... rotation is clockwise......advancing is by twisting it counter clockwise...once I got it right, I marked it by punching marks in the aluminum with a sharp wood chisel.
    If you can't see 24 with lines plugged, rotate distrib until you can....presuming I did mine right... I may look it up again when I have time...-Bob
  1. Timing Marks?
    By Tailfin in forum 3geez Accords
    Last Post: 10-11-2006, 06:08 PM
  2. timing marks for auto?
    By othick in forum 3geez Accords
    Last Post: 02-13-2004, 12:07 AM
  3. Timing Lines or Timing Marks...
    By 87lxaccord in forum 3geez Accords
    Last Post: 11-05-2003, 07:46 PM
  4. how to find lost timing marks
    By rbeaud in forum 3geez Accords
    Last Post: 10-04-2002, 01:45 AM
