My shop had some water damage and the result is leading me to give up on this project that I waisted thousands on. I have a completely machine shop finished a20a3 Head (12v, and interchangeable with the a20a1 block)
With the Machined head I have
Entire rocker arm assembly and caps
Used valves
Bisimoto -Never even got to use- stage two cam
Bisimoto -Never even got to use- A series upgraded springs
Less than 2k on a Basically new 38/38 weber
I was planning on taking the valves to the machine shop and assembling the head with all the parts assembled so it will be a few head bolts away from installation.
Also the weber is still bolted to the intake so I could always pull that off and just put it straight on the head. I have a valve cover with the paint removed, but it hasn't been blasted and painted yet.(free)
Basically if your lookin for some bolt on performance, Please hit me up with an offer.
Total cost:
Head + Work = $325
Cam + Springs = $400
Valves = (its about) $50 for a full 3 angle valve grind on 12 valves
Weber = $350
So thats about 1100 or so and I would easily take 800 or something around there, Best offer.
Thanks for looking, my name is Matthew and you can reach me at [email protected]
