Can it be done? Has it been done?
It would seem that if the 3g's auto is not electronically controlled, which I don't think it is, then the only issue a manual trans OBD1 ecu would have would be making sure the engine maintained idle while stopped in gear. The IAC on the 3g seems to be vacuum operated, so a fix should be pretty simple. Thoughts?
