Ok so I'm in the drive thru at Mc Donalds yesterday and i notice that my temp is 3/4 the way to the top! so i turn my fans on high and roll down the windows and the temp needle did go down to about halfway. So i got it home and i changed the thermostat, at first it seemed as if it it would work then nope, same problem. The coolant is at the proper level, no leaks. It seems to want to go high like that after about 10-15 minutes of driving and when im at an idle. So i was wondering if anyone knew what the problem could be? Maybe a sensor? i duno. Mycar is an 86 carbed if that helps at all. Thanks.
