Results 1 to 12 of 12
Thread: easiest/fastest way to reach the oil filter . wich is it?
    LX User ADRIANFARINA's Avatar
    Mar 2010
    86 Hatchback , 97 TL1000S , 39 Zundapp DB200 , 68 Vespa , 79 Derbi Variant , 96 CN250
    Tel-Aviv
    Question easiest/fastest way to reach the oil filter . wich is it?
    on the 86 carburated engine.
    thanks !!
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Re: easiest/fastest way to reach the oil filter . wich is it?
    Quote Originally Posted by ADRIANFARINA View Post
    thanks !!
    From the bottom when you drain the oil.
    Remove the driver's side wheel.
    i just reach down from the top and drop it into the oil drain pan.
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    If it's all stock then the easiest way is to get it from the bottom because all the vacuum lines and crap are in the way on the top. I guess you could take off the drivers side wheel, but why bother when you have to crawl under the car anyway to drain the oil?
    you don't have to, a low profile oil pan will slide right under the car, and you can reach the drain bolt from in front of the car.
    Mar 2010
    Tel-Aviv
    and to fill the automatic gear oil? should I do it from the gears dipstick? how much should I put in?
    btw , engine oil , only three liters needed?
    thanks
    Jan 2010
    thanks
    I've used Dexron II tranny transmission fluid.
    Mar 2010
    Tel-Aviv
    Quote Originally Posted by stephensimmons View Post
    I already bought the oil , how much should I use?
    thanks,
    Adrian.
    Aug 2007
    Boise, ID
    It's been so long since I've had a 3gee with stock ride height that I forgot you could even get a hand under the car without jacking it up.
    SEi User dacantu's Avatar
    Jan 2009
    Phoenix
    I believe its 3.17 quarts of oil with the new oil filter on there.
    -dan
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    3.5 liters with a filter says the manual
  1. Replies: 63
    Last Post: 11-23-2009, 05:33 PM
  2. fastest 3g?
    By Nik247 in forum Performance
    Last Post: 07-04-2009, 08:32 AM
  3. anybody trying to reach me diffeent email addy
    By Sean in forum Classic Honda Community Chat
    Last Post: 09-13-2004, 07:32 AM
  4. Ok...Wich One??
    By tuner4life in forum Classic Honda Community Chat
    Last Post: 04-11-2004, 06:10 AM
  5. Too lazy to reach past steering wheel...
    By Dia Fria Claro in forum Interior & Exterior Care
    Last Post: 10-24-2002, 06:32 PM
