i thought i would post some progress on the install of the new audiovox ax 510 car alarm i'm putting in,for security reasons i'm not going to post some info,but other stuff i will
the harness for the shock sensor and the special dual color LED wasn't long enough so i ended up extending it. i don't believe in the slap it behind the dash with zip ties garbage.
if you are going to put in an alarm this complex,it takes time. everything in the new harness is soldered and heatshrunk. i extended the harness and added the connectors
one thing i hate about alarm installs is they always have a hole in the dash that looks like crap,for the LED. i was using a factory nissan security indicator, which worked well,but the new LED is a special dual color one. the factory indicator had an led that snapped into the back of it with a plug. this required me to make an aluminum adaptor,that epoxied into the housing.
i'm adding power door locks to this setup, so i modified a rear drivers side power window switch. it should fit nicely under the edge of the armrest.
