Results 1 to 12 of 12
Thread: 2-speed hondamatic driving
    Mar 2010
    1977 Honda Accord CVCC
    I'm trying to figure out whether it's my use of the Hondamatic or a carb problem here.
    When I slow down in my '77 accord to take a curve, I find that the car has no power after taking the curve.
    So I'm wondering if I should be shifting the 2-speed hondamatic to first gear (like a manual transmission car) or there is a problem with the carb (power circuit etc).
    What do you think?
    Thanks!
    Re: 2-speed hondamatic driving
    I was under the impression that you still had to shift the Hondamatic between 1 and 2? Have you tried shifting to 1st gear? What happens? Could be your float is low and the fuel is sloshing over to one side... does the car sputter and miss, or is it just lacking in power?
    I think you have to shift it
    Mar 2010
    Thanks, guys. I'll try it this weekend.
    I would say that you should swap that out for a manual, but there's probably some novelty value to a 2-speed auto by now. I'm so glad my '76 had a 5-speed though.
    naa the hondomatic sucked pure and simple, it was a bomb
    Ichiban's Avatar
    North of You.
    I'm sure you had to shift those.
    ICHIBAN!
    "Now, even more better!"
    LX User 1GCustomAccord's Avatar
    Jun 2008
    79´Accord,83´Lude,71´Nova coupe,83´Pontiac 6000,69 Mustang coupe,and many more rusted crap...
    PY
    I dunno.. Maybe you have low fuel level in the carb, thats why you loose power in curves at high speeds. I dunno much about the 2 AT, since i only drive the 3 speed AT. It has "L" a STAR and OD , when you want to go, the "star" is good and makes 2 speeds, then if you are cruising, you can shift to "OD" ( Above 45 KPH) .
    "L" is just for towing and etc.
    So many reasons why
    I won't be sending postcards
    From Paraguay
    ^^^^it says in the manual to allways use L when tasking of from a standstill i heard
    my crx is hondamatic 3 speed i drive it like a manual pretty much, L, Star and then into OD
    Jun 2008
    PY
    Oh yes, thanks for pointing that. I forgot about that since i sold my AT long ago. "L" is the position to start and then "star" and OD above 45 kph.
    So many reasons why
    From Paraguay
    Mar 2010
    I tried the car again this morning: this time shifting down to first when slowing down to take a corner.
    It looks like it's something wrong with the carb. There is just no power after the corner.
    Thanks for the responses.
    here's a link to probably the best rebuilder of these, and probably the cheapest. those carbs are not easy to fix, it's probably worn out
    http://www.importcarbs.com/
  1. Hondamatic Ratios
    By Traco in forum 2geez Tech & Performance
    Last Post: 05-28-2010, 06:09 PM
  2. Driving up hill....
    By DEEGO in forum Performance
    Last Post: 06-18-2009, 08:10 AM
  3. Driving around
    By 89accordky in forum Classic Honda Pics & Videos
    Last Post: 01-15-2009, 09:49 PM
  4. 5 speed, trans from 87 lx-i in 89 lx 5 speed.
    By Soopitup in forum Performance
    Last Post: 03-02-2008, 08:47 PM
  5. Driving to MI from TX, anyone in between?
    By 86LXItooFAST4me in forum Classic Honda Community Chat
    Last Post: 06-09-2004, 07:23 AM
