Results 1 to 3 of 3
Thread: Carb to FI swap - quick questions
    Dec 2009
    St. Louis, MO
    I'm gonna be trying a carb to FI swap this summeron my 89 LX. I have the following but they are from an 86.
    -Intake Manifold w/cleaned injectors w/new grommets
    -Engine harness
    -Vacume Box with all vacume lines labeled (including hard lines)
    -Dizzy
    -Ignition Coil
    -ECU w/ plugs
    -Fuel Pump
    -Gauge Cluster
    -Engine Bay Fuse Box
    Now, I know I'm gonna want an 88-89 intake manifold with injectors because it creates more power than the single stage 86-87. But will the 86 ECU and engine/dash harnesses and everything work with the 89 intake mani? I think I'm about 50% the way there in terms of parts (biggies now are fuel tank and fuel lines, thermostat, and harnesses and alternator) but I'm hoping that the stuff I have already isn't completely useless now.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: Carb to FI swap - quick questions
    Your going to need 88-89 would be easier and don't need the 86 ecu harness need a 88 89 ecu and your using the same engine or getting an a20a3?
    Dec 2009
    St. Louis, MO
    Using my carbed engine. After reviewing the conversion, I'm thinking I may be better off just buying the Innovative mounts because it seems then all I need to do is add the fuel line and swap the gas tank and fuel pump, and the rest will come with the new engine. =/
    So I guess you guys will see some 86-87 fuel injected parts for sale soon! lol
  1. 2 quick questions.
    By drock in forum Classic Honda Community Chat
    Last Post: 02-10-2011, 11:47 PM
  2. Quick carb question
    By CzEcHy in forum Carburetor Tech
    Last Post: 04-19-2010, 09:36 AM
  3. A few quick questions
    By tedhodges in forum Classic Honda Community Chat
    Last Post: 01-20-2006, 06:26 PM
  4. A couple quick carb measurement questions.
    By 120hpcanadian in forum Classic Honda Community Chat
    Last Post: 02-27-2004, 04:10 PM
  5. Quick questions
    By HondaSi88 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-30-2003, 04:30 PM
