Results 1 to 8 of 8
Thread: Repairing an ECU
    carotman's Avatar
    Montreal South Shore
    Repairing an ECU
    I have a PJ0-A03 here that has a fried component in it. I don't know what the original owner did with it but the driver for the fuel pump relay is busted.
    I wanted to repair this ECU and build a small ECU repair Database for our cars at the same time.
    The fried part is a PU3127. I downloaded the datasheet and it seems this is only an array of 3 NPN transistors with diodes.
    (here's the datasheet).
    http://www.datasheetarchive.com/pdf-...DSA-154322.pdf
    I've seen a PJ0-666 and this thing uses 3 D1259A instead of the PU3127.
    used individual 2SD1259 transistors instead of the transistor array. (Individual Transistors)
    http://www.datasheetcatalog.org/data...JD00175BED.pdf
    Anyone knows what kind of equivalent transistor could be used? NTEXXX?
    I need these parts!
    cygnus x-1's Avatar
    Chicago area
    Re: Repairing an ECU
    That's going to be an tough one to find a pin compatible replacement. That datasheet looks like it's from about 1981. NTE, Digikey, and Newark don't list anything that's pin compatible. You're only option is going to be to find some compatible discrete devices and wire them in. Digikey has a parametric search so you can filter down to find something that will be compatible. You want something similar or better specs; they don't have to be exactly the same.
    EDIT: I wonder though. I just removed the ECU from my Prelude because I'm not using it anymore. If you want I could check to see if it has a compatible part on it. The ECU is junk to me.
    C|
    carotman's Avatar
    I already planned to wire compatible components on a custom PCB to replace the parts. Just like How Doc Brown replaced components in 1955 on the DeLorean
    If you have a junk ECU, I could use some components indeed.
    I need these parts!
    cygnus x-1's Avatar
    Chicago area
    It got Marty back to the future right? Ever seen wire wrap construction? Crazy stuff.
    I'm looking at it right now. There aren't any 3x transistor arrays like your fried one but there is a 4x. There are also a lot of B744A transistors. Not exactly like yours but they might function well enough.
    This "ECU" is from a carbed car so it doesn't do fuel injection; only emissions controls. I don't know if it would do you any good but I'll send it to you if you want it.
    C|
    Oct 2000
    '88 Accord LX-i
    Connecticut
    I got a junk ecu and I am coming up to Montreal this weekend. if your interested I can bring it.
    '88 LX-i Coupe --- LS/Vtec
    carotman's Avatar
    Yeah why not
    I need these parts!
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Yeah why not
    now I just have to find it...
    SE-i Sedan 5 spd
    You guys are intrepid!
  1. Repairing carburetor diaphragm
    By 88Accord-DX in forum Carburetor Tech
    Last Post: 09-18-2012, 07:48 PM
  2. repairing combo switches.
    By lostforawhile in forum 3geez Accords
    Last Post: 12-31-2005, 07:31 PM
  3. Repairing rust
    By FyreDaug in forum 3geez Accords
    Last Post: 06-08-2005, 01:26 PM
