Hi new to the forum quick ? loud whaaaaaaaaaaaaaaaa noise at any speed over 10mph cv was just replaced and noise goes away completely when i turn left. wheel bearing? alingment? or tire?
wheel bearing possibly , jack up car grab tire wiggle it side to side if any play replace bearing.
last wheel bearings i had replaced were on my toy. It was around 380 each.
I'd say tire. What tires are you running and how old are they?
Lol I was stupid at the time. Didn't know anything about cars.
I ended up wasting 3 grand on a transmission replacement on the car. later found out how badly I was screwed *this was one of the big dealers.*
So I decided I was going to learn as much as I can and do all of my fixes myself.
They also wanted to charge 1 grand just to replace the bloody timing belt.
Which I did in myself on my 3g. :P
check the brake pad chirpers (warning that you are almost out of brake pad), quick, before you lose the rotor...
ok i had a friend mechanic do the wheel shaking test to feel for play he said there wasnt any. i forgot to mention that the noise changes slightly when braking.
the next thing to do would be to go check the brake pads as griffonks suggested.
honduh
get a wheel alignment.
just about bet on thats what it is.
I'm still voting tire.
thank you for all the help ill check the brakes on my next day off and get an alingment check
