lol
Personally I think they are both common. Right now my RL has deposits on the front rotors causing a slip/stick situation that I can feel. Most would confuse that with warped. The original owener simply had the pads replaced. The rotors are not warped.
My wifes car (2000 Accord) warped the rotors with the oem pad from overheating. Turned rotors replaced with better pad and problem solved.
You really have to know what your up against since they can be mistaken for one another.
I'm a firm beleiver in turning rotors though.
