Alright. Its been awhile since I posted haha.
My last big project was installing the Weber which worked well.
My engine is still having a massive idle fluctuation like with the old carburetor so I am thinking about doing a engine rebuild.
If I do decide to do the rebuild, im going to replace the pistons, valves, springs, rehone the block, replace the gaskets, and paint the thing red (maybe)
What else would be wise to look into while I have it apart like this?
Also.. What else could be causing this bad idle fluctuation?
Itll idle steady until it warms up. Soon as it warms up the idles go from 700 - 1200 and back down over and over and over when it idles. It gets worse and worse till it shuts off and to get home I have to pop it into neutral and keep it revved.
I wouldnt assume its the carb since its a brand new one and the install went perfect.
I think it has to be something in the internal engine causing this. Way back when before I got the car (my dad owned it new off the lot) The timing belt apparently broke and possibly caused some damage on the internal engine componets.
That is my basis for why it would need the engine rebuild, That and it has a good 230k on it.
Any insight would be amazing guys. Thanks.
