Alright!! So, worked all friggin day, just got done. Replaced water pump, timing belt, other aux belts, bled brakes, new pwr steering pump, new fluids across the board, fixed ac, fixed cruise control, set timing, oil, oil filter, new valve cover gasket, adjusted clutch, and for sharts n giggles, re-did all of the vacuum lines again. lol so its running and idling (although a bit high) and the clutch has a lot more play to it, a bit over half the clutch pedal. We adjusted it as much as we could, to get more play out of the clutch pedal, what else can i do?
We noticed that the float is bad on the carburetor so i was wondering do i need a new carb, rebuild kit, or just buy the float?
And right before we were going to call it a night, i was moving the distributor to adjust the timing and the dashpot with the 2 vacuum lines snapped. xD FAIL. lol, was also wondering can i just buy the new dashpot piece or do i need a new dizzy?
And, here is a pic below of the brown beast. GAWD i cant wait to strip the paint lol
The hood isnt uneven, just unbolted and sitting on top
