Results 1 to 13 of 13
Thread: anti-freeze/coolant leak
    My car started leaking coolant and I can't figure out where it is. I'll post some pictures in a bit to see if anyone could help. It's coming from the area between the thermostat and EGR valve. It doesn't seem to be coming from the thermostat, and I just changed it along with the seal about a week ago. This is preventing my car from being able to go any distance without flushing the entire coolant system the second I turn my car off. Oh, I forgot: It doesn't seem to leak when the car is running/driving, but the second I turn the car off, it will start leaking. It's very odd, too, because I can drive two miles home from school and it will leak all of the coolant, but I could also drive to Seattle and back and it won't leak a single drop. I've changed several (but not all) of my radiator hoses in the past few months. Any help would be great because I have a 600mi trip coming up that I cannot miss. Any ideas?
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Re: anti-freeze/coolant leak
    Get you a pressure tester to go on the radiator then pressureize it and look.
    How did the thermostat housing look when you opened it up. Spic-N-Span or kinda cruddy and nasty?
    ^ It looked "rusty".
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    when you change several hoses you got to change all of them you must have a rotten hose somewhere check all hose clamps,inspect for any sign of cracks or expanded when hoses are normal(cold) on the hose and guessing it wouldn't leak cause the hose is hot and it expands so that could be why it wont leak when running. tighten clamps to see if thats your problem if not change the clamp might be old and not have a good tight clamp
    Are you sure you got a good seal when you put it back together?
    Oct 2009
    or did he get a seal that wasnt the correct one?
    [blah]
    I've checked all of the hoses I can see. The thing is, it seems like it leaks too much to be just a crack in a hose.
    Yes.
    The seal came with the thermostat.
    Jan 2010
    Get a pressure tester. Or atleast pressurize the system somehow if you dont want to buy one.
    ^ I really don't know how to, so I'll have to get a tester. Are there places that rent them?
    Jan 2010
    Try autozone or advance
    LX User M3Galaxie's Avatar
    Apr 2007
    1989 Accord DX
    St. Louis
    I had a leak coming from the same area. My was coming from the back side of the thermostat housing. The metal sleeve that the hose was connected to had rusted out.
    '91 Kawasaki ZX600c =D
    '89 Accord DX A20a1 5spd
    '68 Ford Galaxie XL 396ci-Fe C6
    '07 Mazda 6 2.3L 5spd
    How bad was it to replace?
  1. Serious coolant Leak
    By ProShift in forum 3geez Accords
    Last Post: 11-18-2010, 08:26 PM
  2. Coolant leak?
    Last Post: 09-20-2010, 10:51 PM
  3. Anti freeze motor drain plug
    By -$MOKIN- in forum 3geez Accords
    Last Post: 04-11-2009, 07:42 AM
  4. Coolant Leak
    By jduncan in forum 3geez Accords
    Last Post: 12-15-2008, 03:34 PM
  5. coolant leak
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 09-05-2006, 09:11 PM
