So I've been running my car obd1 for a while now and everything's great except I keep getting a code 17. The strange part is that I only get it when I rev up to redline. I can drive normal all day long and never get the code, but right when I redline it I get a solid cel.
I have modified the vss wire to be tapped off of the speed pulse wire with a 6k resistor. I did not install a diode on the cruise wire since I do not have cruise and I long ago removed the module. Is the diode needed even if I don't have cruise? Or is not having the cruise module causing a problem? And why am I only getting the code when I redline?![]()
