Results 1 to 6 of 6
Thread: 87 Accord LX (rebuilt motor,dcoe,suspension & more)
    87 Honda Accord
    Bellevue NE
    here is my UNFINISHED project
    PART OUT PRICES BELOW!!!
    Shell
    Clean
    DX
    Auto originally
    77k
    1 owner
    motor itself(0miles)
    A20A1
    Skimmed block and head
    ALL OEM HONDA PARTS USED(I work there)
    oil pump/seal
    water pump/seal
    timing belt
    front main
    rear main
    Cam seal
    dist. O-ring seal
    water pipe 0-ring
    head gasket
    dowel pins
    intake manifold gasket
    exhaust manifold gasket
    dip stick
    oil pan(all new bolts)
    oil pan gasket
    oil pick up tube seal
    oil filter housing gasket
    breather box and seal
    Engine power adders
    Delta 272 Regrind(0 miles)
    Pacesetter header (0 MILES AND MODDED LEGIT)
    Exhaust(still needs made i will give you the materials)
    Summit Racing
    2.5 piping (8ft)
    2-2.5 adapter
    2.5 U bend
    2.5 45* bend
    Weld rod for hangers
    Spoon N1 style muffler
    Ignition
    NGK Wires
    NGK plugs
    Honda dist. cap
    Honda dist. rotor
    Fuel
    Custom tubular DCOE manifold
    Weber DCOE40 carbs (rebuilt by me)
    Weber linkage kit
    Weber fuel "T"
    Weber 90* fuel inlet
    Sock Filters
    Spectre see-through filter(engine bay)
    Honda rear fuel filter
    Honda throttle cable
    Anti-Vibration Mounts
    JET kit for tuning the carbs
    Handbook for tuning the carbs
    Cooling
    Radiator Depot radiator(never added coolant yet)
    VS racing Slim Fan
    blocked off all coolant ports (head,t-stat housing, and water pipe)
    Honda radiator hoses
    Honda thermostat/seal
    Honda thermostat housing (both pieces)
    Honda T-stat housing seal
    Trans
    5spd
    86 Prelude SI 135k
    NO GRIND,NO POP OUTS, VERY SOLID
    Exedy stage 1 (0miles)
    Resurfaced OEM flywheel
    Honda clutch cable
    Honda clutch return spring
    ES shifter bushings
    Syncromesh(even tho tranny was mint i still love that stuff)
    Autozone Axles
    Suspension
    Skunk2 Integra sleeve-overs
    KYB GR2 shocks(for accord)
    Honda rear shock bushings & bolts
    ES ball joint boots
    Brakes (around 20miles on them)
    Honda pads
    Honda rotors
    Interior
    black 3g lude seats
    GUTTED
    Crown Royal Shift boot
    Body (for the year)
    7 out of 10
    Interior
    GUTTED but has nice paint
    LOL (it was mint if your serious ill tell you the story)
    Mechanically
    IDK hasnt been started
    Should get down tho
    Pics (good ones will come this weekend)(ill snag interior pics when lude seats are in)(hood is also on now)
    Car will be on OEM steelies and Great all season tires
    THROW ME OFFERS
    2750$ or offer
    I have close to 4k into the car, so don't try to rape me!
    87 Honda Accord
    Bellevue NE
    Re: 87 Accord LX (rebuilt motor,dcoe,suspension & more)
    car needs exhaust and the carbs adjusted to run
    i havent even bothered to try to start it
    87 Honda Accord
    Bellevue NE
    lots of service records go w/ the car also
    steering rack it new but lines are cut bc im not running p/s
    87 Honda Accord
    Bellevue NE
    will consider part out
    lmk what you want
    also many parts are new or gently used
    87 Honda Accord
    Bellevue NE
    D16Z6 (Del SOL) valve cover ([H] and honda under it) 20$
    D series shifter linkage w/ poly bushings 20$
    92-93 DA bumper lights 10$
    86-89 Accord OEM exhaust(cat included)(new from honda as of july 09) 150$
    5x 13inch steelies & hubcaps w/ excellent tires 150$
    6.5 Rockford Fosgate speakers P162S 50$
    EG coupe (power) mirrors OEM 40$
    0bd2 LS integra Distributor(one leg chopped to work on VTEC head)(works great) 50$
    8 ft of 2.5 piping $50
    2.5 U bend(mandrel) $30
    2.5 45* bend $30
    JSR Spoon N1 style muffler(new) $100
    Innovate LC1 wideband(new) $175
    BMW Bottlecap Wheels
    Matte Black (fresh powder coat)
    195/60/14 Falken Azenis 0 miles
    500$ or offer
    Skunk2 Sleeve Over coilovers
    0 miles
    94-01 Integra but will fit others
    250$
    86-89 Accord KYB GR2 Shocks
    0 miles
    150$
    Radiator Depot radiator for 86-89 Accord w/ new cap
    mounted but never filled
    100$
    86-89 Accord Clutch Cable
    Intalled (but new)
    40$
    Civic/Integra Poly balljoint dust boots
    15$ for all 6
    ****Complete N/A A20 swap for 3rd gen Accord/2nd gen Lude FULL SWAP 2200$ (carbs and all)****
    A20A1
    oil pump/seal
    water pump/seal
    timing belt
    front main
    rear main
    Cam seal
    dist. O-ring seal
    water pipe 0-ring
    head gasket
    dowel pins
    dip stick
    oil pan gasket
    ARP headstuds
    Autozone Alt. (0miles)
    New Alt. belt
    vc gasket
    vc grommets
    K&N breather filters(2 of them vc and breather)
    Delta 272 Cam
    Pacesetter header
    wrinkle finish valve cover
    Fuel
    Weber linkage kit
    Weber fuel "T"
    Sock Filters
    Ignition
    NGK Wires
    NGK plugs
    Honda dist. cap
    Honda dist. rotor
    Cooling
    Trans
    5spd
    86 Prelude SI 135k
    Honda clutch cable
    ES shifter bushings
    Autozone Axles
    Powdercoated mounts front, rear, and rear upper
    ****end of motor swap list****
    will add more as things come up (garage is a mess)
    offers will be considered! low balls will be ignored
    87 Honda Accord
    Bellevue NE
    car is stripped and parts are ready to go
    will sell the shell for 300
  1. Sickest3g se-i stock rebuild motor/suspension/5speed swap
    By Sickest3G in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-24-2012, 03:08 PM
  2. Replies: 5
    Last Post: 09-08-2009, 10:41 AM
  3. New Pics ...rebuilt Motor!!!!
    By PearlDrummer00 in forum Classic Honda Pics & Videos
    Last Post: 01-18-2007, 09:45 PM
  4. Motor : Fix/rebuild/buy rebuilt/or keep putting
    By jigga225 in forum Classic Honda Community Chat
    Last Post: 05-01-2005, 10:19 AM
  5. Rebuilt motor from accordcentral, I got some ?'s...
    By SEiCOOLGUY in forum Performance
    Last Post: 07-12-2004, 07:38 PM
